00 integra dash w/b18b1 and b16 cable trans swapped into 92 civic cx, which vss??
Old Jun 11, 2008 | 04:55 PM
95dc2teg's Avatar
Default 00 integra dash w/b18b1 and b16 cable trans swapped into 92 civic cx, which vss??
I just bought a 92 civic cx that has a 00 integra dash and a 2000 b18b1 with a cable b16 trans that was converted to hydrolic with the hasport kit. Now, the car runs and drives fine, but the vss does not work and the check engine light will come on. I replaced the speed sensor with one from a 95 integra gsr and it worked for like 3 minutes then started jumping around and then finally just stopped working as well. Now what do i need to do to make this work?? Do i neeed a cable speed sensor or should i totally rewire from the harness to work with the electrical sensor? Please help me out! TIA!
laloquera916
Sep 17, 2010 12:40 PM
samhonda95
Transmission & Drivetrain
Aug 15, 2009 09:37 PM
mugenpower95eg4door
Nov 9, 2007 07:35 PM
shane
May 26, 2003 10:09 PM
