HELP! Want to swap GSR/w LSD tranny, in DX, non vtec auto coupe. Help!
I haven't actually started the swap but i want to know what all i am going to need to do the swap right. (mounts, wiring harness etc.)or any problems you may have encountered. I know i need the pedal assembly and clutch master cylinder & resovior from a civic, but i have heard that the tranny mounts/brackets are different on auto/manual.....Should i buy the HASPORT auto to manual conversion mount? I plan to buy a complete swap from either JHP or PASSWORD so i will have the mounts and wiring harness from that but don't know if they are compatible with DX non-vtec auto.... Any info would help! Thanks!
aside from the regular motor mounts ur also gonna need the rear engine bracket or "L bracket". i found that out the hard way
passwodjdm.com and jhpusa.com, i've bought stuff from both of them in the past and no complaints, you also might want 2 check some of your local shops, compare prices, its always a good idea you might get a better deal
I recommend getting the auto>manual tranny mount from Innovative Mounts. Made of steel (although they do offer billet) and therefore cheaper than Hasport.
You will also need the hard line + flex line from the clutch MC to the clutch slave cyl, among other misc parts that I am too
to think of.
to think of.
i've asked around and so far it's a yes, you do need it. i'm gonna see if i can dig up some more info. Ask around, maybe you'll find something too. i'll keep you posted if i find anything.
HA! I forgot to tell the n00b to <u><FONT COLOR="red">Search</FONT></u>
https://honda-tech.com/zerothread?id=1316692
https://honda-tech.com/zerothread?id=2090074
nastyboyz98civic
Aug 15, 2008 11:42 AM
importwarriorsi
Oct 22, 2006 03:43 PM
T_bones
Jun 11, 2006 03:41 PM
dailygirl
27
Jun 17, 2004 10:10 PM
