Anyone familiar with all of the cams that Blox offers?
My buddies and I have had great luck with Blox cams for the past few years, and I haven't really kept up with what they currently offer. If I order a set, which set will be the best all motor cams? I'm looking at throwing my fully built head on a stock GSR motor with PR3 pistons for a short time, then putting in my 2 Liter B16 when I don't need to daily drive this setup. I could care less about idle quality, and I just want the set of cams which will make the most usable power for my application.
are the HSL's the current "best" ones to get? and aside from that, I notice blox makes cams with stock width cam lobes and then some "competition cams" with wider cam lobes. What benefits do wider cam lobes offer? I'm assuming they mean the cam profile is the same and the cross-sectional width is larger, right? Seems like wider lobes would equal heavier cams, and I'm not sure if that's a good thing.
What do you guys think?
thanks for the help,
Mike
Mike
You can thank Skunk and Jun etc for the great cam profiles that Blox offers as they did all the R&D and Blox copied them. That being said, there are no "best all motor" cam profiles where one profile is best for all all motor applications. The more you change your setup the more likely it will be that different cams they offer will perform better in different engine combinations.
To be honest, I would say either the Blox B's or the Blox type C's would be the best cams that should work well in each of those setups you mention.
The pro series stage 1 might be a good choice as well... it will have a broader midrange.
Edit: yes I mean blox pro not skunk.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikesrex »</TD></TR><TR><TD CLASS="quote">I don't remember seeing the C's on their site. Guess they don't update it very often?</TD></TR></TABLE>
C's are an exact duplicate of Jun3's, primaries and all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00Red_SiR »</TD></TR><TR><TD CLASS="quote">, there are no "best all motor" cam profiles where one profile is best for all all motor applications. </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2LEM1 »</TD></TR><TR><TD CLASS="quote">The pro series stage 1 might be a good choice as well... it will have a broader midrange.
Edit: yes I mean blox pro not skunk.</TD></TR></TABLE>
Are the pro series stage 1 identical to the s2 pro 1's on the market now, or a copy of s2 p1 prototype?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg »</TD></TR><TR><TD CLASS="quote">
Are the pro series stage 1 identical to the s2 pro 1's on the market now, or a copy of s2 p1 prototype?</TD></TR></TABLE>
I don't think the specs are identical, however they did copy skunk's fast ramp technology and it is an improved primary profile.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rollo Lawson »</TD></TR><TR><TD CLASS="quote">i heard a while back from a good source, that hsl is a toda/jun combo</TD></TR></TABLE>
the HSL is the skunk2 stage 3 which is nowhere near a toda jun combo, its more like stock primaries, and skunk spec vtec lobes
Copy of the prototype.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by oldskool teggy »</TD></TR><TR><TD CLASS="quote">
the HSL is the skunk2 stage 3 which is nowhere near a toda jun combo, its more like stock primaries, and skunk spec vtec lobes</TD></TR></TABLE>
i don't know man. hsl might have a similar vtec lobe as the s2s3's but thats probably about it. who knows, i could be wrong
