ABS light is on...how do check to see if its a bad sensor?
Old Jun 11, 2008 | 02:45 PM
supermotothud's Avatar
Default ABS light is on...how do check to see if its a bad sensor?
MY ABS light is on, and I want to check to see if its a bad sensor.....which i hear is common for it to fail.
Do you need a OBDII scanner?
I keep on hearing about some paper clip method, but i cant seem to pull up on the searches what it is and how to do it.
Old Jun 11, 2008 | 04:54 PM
Mr Yamada's Avatar
Default Re: ABS light is on...how do check to see if its a bad sensor? (supermotothud)
Old Jun 11, 2008 | 05:05 PM
Default Re: ABS light is on...how do check to see if its a bad sensor? (Mr Yamada)
oh whoops....i thought i had my signature up...
Its a 1996 Accord EX, coupe, automatic , F22b1 with a lovely 178k on the clock.
Old Jun 11, 2008 | 06:14 PM
Mr Yamada's Avatar
I believe on your model you can retrieve a flash code by using the blue 2 pin connector behind the glove box/above the passenger side kick panel.
Insert a jumper and turn on the key.
Thelandlordsmm
Aug 3, 2009 07:30 PM
ClarkS40
Mar 21, 2009 11:59 PM
major
Sep 13, 2006 05:53 PM
MF-DIF
Feb 11, 2004 05:35 PM
