clutch help
i have a 91 accord ex 4dr 5spd manual and the clutch just went out... i just park it in the front then, i came back to start my car... the clutch went flying to the floor... and it doesnt come back. i have to grab it back... but even still when i try to start, it doesnt go in gear... so if theres any parts i need or anything esle please let me know... this just started to day. Pics would help me alot. thanks alot in advance
I might suggest that you check the Clutch master cylinder reservoir level.
It uses brake fluid. DOT3 type.
Then with a flashlight look up under the driver side dash to the point where the clutch pedal arm connects to the clutch master cylinder.
See if there is fluid seeping out, if so it indicates the clutch master cylinder needs replacement.
On the front of the transmission housing is a slave cylinder [down low] that actuates the clutch pivot arm, also check there for fluid leakage.
Fullthrottlegsr
Jun 22, 2005 01:21 PM
DriveSideWays
Aug 27, 2004 05:06 PM
