Brake light switch, shift lock
Old Jun 11, 2008 | 01:31 PM
geneva's Avatar
Default Brake light switch, shift lock
Hello. My 92 accord ex is stuck in park (can be over-ridden with shift lock in center console) and my brake light are out. I checked all the fuses in both boxes. I know I should now check the brake switch, but I don't know what that is or where it is, other than somewhere under the dash by the brake pedal. Any help?
Old Jun 11, 2008 | 01:46 PM
jeger's Avatar
Default Re: Brake light switch, shift lock (geneva)
I have a manual transmission but my brake lights went out a bit ago, i pulled the switch from under the dash behind the brake pedal, un crimped it then removed the metal housing, remove the two contacts that hold the pin in, then clean the sliding contacts, when you put it back together make sure the springs are seated right or the pin wont recese far enough, put it back together recrimp it with pliers reinstall it, saves you about 40 bucks to fix the swicth instead of buying a new one. Might want to check it with a ohm metter diagonal pins should have one thats on when depressed and one that's open when depressed, when released the opposite is true.
Hondaman22
Aug 25, 2023 08:08 AM
DeeFry
Dec 2, 2018 09:41 AM
PREACHERBREW
Jun 5, 2008 03:47 PM
Jedimiah
Jun 8, 2007 11:04 PM
SlowDC4
May 18, 2006 08:02 AM
