Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
4wd in honda crv
Old Jun 10, 2008 | 10:59 PM
crvsam's Avatar
Default 4wd in honda crv
does anyone know if you can take the 4wd out of the honda crv? and how hard it is?
Old Jun 12, 2008 | 02:55 PM
downloader's Avatar
Default Re: 4wd in honda crv (crvsam)
just remove the propeller shaft, and you have a fwd,easy
Old Jun 14, 2008 | 01:11 PM
crvsam's Avatar
Default Re: 4wd in honda crv (downloader)
is it something easy? or is it something you would have to have a professional do?
Old Jun 14, 2008 | 01:51 PM
Hawkze_2.3's Avatar
I removed the back half of mine and it was pretty easy. I cut the rear axles (they were badly rusted anyway), removed the remaining part of axles by separating the outer CV joints, removed the rear differential, and removed the driveshaft.
It was about 90lbs of weight total and a good amount of reduced rotational resistance. I guess you could just remove the driveshaft, but then you still have lots of dead weight back there and a differential to fight against.
Old Jun 16, 2008 | 10:55 AM
crvsam's Avatar
Default Re: 4wd in honda crv (Hawkze_2.3)
sounds like a lot of work haha
Old Jun 16, 2008 | 12:08 PM
godspeedcrv's Avatar
Why do you want to remove your 4WD?
Old Jun 16, 2008 | 10:25 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crvsam &raquo;</TD></TR><TR><TD CLASS="quote">sounds like a lot of work haha</TD></TR></TABLE>
Working on cars usually is work, don't be lazy
Old Jun 17, 2008 | 07:38 PM
crvsam's Avatar
Default Re: 4wd in honda crv (godspeedcrv)
so i can get more power. plus my 4wd makes this real obnoxious noise when it kicks in and ****.
Old Jun 18, 2008 | 08:34 AM
Could be your differential fluid that needs changing. How much power are you looking to get out of it? Whats your goals for the CRV?
Old Jun 21, 2008 | 09:28 AM
crvsam's Avatar
that noise has happened ever since we bought it in 97. my goals. are to dropped the awd, make it 2wd. and then drop it about 1.5 inches and get black 16's for it. and the windows tinted and a little bit of stuff under the engine.
spaceman00
Mar 27, 2007 11:47 AM
d1nki
Feb 16, 2007 02:52 AM
drewbie
Jun 4, 2005 09:53 AM
kr3nse0ulja
Dec 12, 2004 11:22 AM
J_J
11
Feb 8, 2004 07:56 AM
