b20 vtec swap now not starting.
Old Jun 10, 2008 | 09:18 PM
ha...tch's Avatar
Default b20 vtec swap now not starting.
i just swapped out my b16 and put in a b20 vtec. i got it tuned and on the way home the car shut off. i left it sit and came back at night fall to test some theories found i had no fuel or spark.check the wiring and checked the dizzy plugs a wire had come loose so i put it back in but still nothing. i pushed the car down the road to a cycle shop and left it sit. went back last night and pulled the dizzy the rotor button was in place and fine. but on the iside of the cover i found almost like a powder residue... did maybe wires criss cross and short out my dizzy is this why im not gettin spark and fuel?
Old Jun 10, 2008 | 09:49 PM
saikouEF8's Avatar
Default Re: b20 vtec swap now not starting. (ha...tch)
check for loose or frayed battery cables, check your grounds, fuses, the igniter, then if u get spark and no fuel, check the main relay
was it running like *** before it shut off? im thinking it would have been hard to tune a car if the firing order was wrong...but if it was and it was tuned this way, id assume u could have flooded ur cylinders with fuel real quick... someone else chime in.
good place to start: https://honda-tech.com/zerothread/1992733
Old Jun 11, 2008 | 06:36 AM
ha...tch's Avatar
Default Re: b20 vtec swap now not starting. (saikouEF8)
no it ran great before it did it. battery cables not touching grounds are ok.
Jap.Doe
Honda CR-V & Element
14
Jul 7, 2012 02:03 AM
11winkler
Oct 31, 2011 06:21 PM
hey man
35
Feb 22, 2011 08:35 AM
GHOSTFACE_B20V
Jul 16, 2009 08:22 AM
b20integrapower
Oct 17, 2006 03:43 PM
