recommended throttle body
Old Jun 10, 2008 | 07:46 PM
CivSiClone_96's Avatar
Default recommended throttle body
hey I just bought a skunk 2 intake manifold and was wondering what size i should use for a throttle body I was thinking 70mm skunk 2 throttle body?. I got a B16A building it all motor build. Thanks.
Old Jun 10, 2008 | 08:13 PM
QuickDxEk's Avatar
Stock throttle body is fine!! Unless you have large cams and alot of compression, a large throttle body on a b16 is a waste. I ran a 65mm on my b16 with skunk manifold and only noticed a small gain top end. (8000Rpm+) Throttle reponse and midrange was terriable. When I sold my 65mm i ended up just throwing on a d-series Tb and it runs fine. Two mos ago I ran 14.60 @ 94.85 with this setup!!!
Old Jun 11, 2008 | 12:47 AM
Dark@Powers's Avatar
Default Re: (QuickDxEk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QuickDxEk &raquo;</TD></TR><TR><TD CLASS="quote">Stock throttle body is fine!! Unless you have large cams and alot of compression, a large throttle body on a b16 is a waste. I ran a 65mm on my b16 with skunk manifold and only noticed a small gain top end. (8000Rpm+) Throttle reponse and midrange was terriable. When I sold my 65mm i ended up just throwing on a d-series Tb and it runs fine. Two mos ago I ran 14.60 @ 94.85 with this setup!!!</TD></TR></TABLE>
AMEN TO THAT!!!, all the dynos I have seen on throttle bodies show little if any gain, all on moderately built engines. It seems to have caught on as a fad tho, as I always see people spending two, three hundred, on aftermarket TB's on a bolt on car...
If you really want to get a bigger TB, just bore out a GS-R one to 64mm to match the bore of the manifold... http://www.maxbore.com
Old Jun 11, 2008 | 04:38 PM
8_6 luder's Avatar
Default Re: (Dark@Powers)
So is that to say that bottle necking wouldn't be an issue with a stock tb on a skunk 2 or euro r and maybe a mild top end setup ?
Old Jun 11, 2008 | 08:40 PM
Default Re: (8_6 luder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 8_6 luder &raquo;</TD></TR><TR><TD CLASS="quote">So is that to say that bottle necking wouldn't be an issue with a stock tb on a skunk 2 or euro r and maybe a mild top end setup ?</TD></TR></TABLE>
Bottlenecking is hardly an issue on the intake side (intake, TB, IM) of the head, at least on stock or mildly built engines.
Throwing on a ridiculously oversized throttle body on these sorts of setups will hurt your flow quality and velocity into the plenum (flow contraction).
Old Jun 11, 2008 | 09:43 PM
Rollo Lawson's Avatar
on a b16, a 68mm tb is a good combo with the p30 im (small plenum). the 16 is picky. going to a larger style plenum will shift ur peak hp very close to 9k, with a stage 1 cam. and even then, u will be sacrificing a good quantity of that ounce or so of wtq the baby 16 has. also more specs of the build would help
Old Jun 12, 2008 | 08:34 AM
QuickDxEk's Avatar
Default Re: (Rollo Lawson)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rollo Lawson &raquo;</TD></TR><TR><TD CLASS="quote">on a b16, a 68mm tb is a good combo with the p30 im (small plenum). the 16 is picky. going to a larger style plenum will shift ur peak hp very close to 9k, with a stage 1 cam. and even then, u will be sacrificing a good quantity of that ounce or so of wtq the baby 16 has. also more specs of the build would help</TD></TR></TABLE>
I ran the 65mm Tb with the skunk manifold and w/o it. The manifold had a more noticable top end power gain, than the TB. The 65mm on bottem end and midrange was horriable. I ran the same 1/4 time with the 65mm than i did with the d-series TB that i have on there. My car car also has alot more midrange and no pre-vtec hiccup!!
91b18a1ls
Nov 22, 2010 08:11 AM
toolbox21
Nov 27, 2008 10:21 AM
Fink2iCe
Aug 20, 2004 10:50 AM
