Fuel Pump - Does not always prime / WHere is the best place to buy one cheap?
Old Jun 10, 2008 | 04:54 PM
bimmeracer's Avatar
Default Fuel Pump - Does not always prime / WHere is the best place to buy one cheap?
My fuel pump does not always prime. Sometimes I have to try for about 10 minutes to get my car to turn on. I changed my ingition and that grey box by the hood latch, which solved the problem for a while, until recently when the car did not start again. I cannot think of anything else to change but the fuel pump. ANyone have any ideas?
Also, if needed, where is the best/cheapest place to buy a fuel pump?
Thanks
Old Jun 10, 2008 | 06:54 PM
ke98248's Avatar
Default Re: Fuel Pump - Does not always prime / WHere is the best place to buy one cheap? (bimmeracer)
Fuel filter?
Old Jun 10, 2008 | 07:09 PM
rSol93's Avatar
probably your main relay
Old Jun 10, 2008 | 07:22 PM
efstile's Avatar
Default Re: (rSol93)
definitely your main relay. wiggle it around, bang on it, or replace it. whatever works for you!
Old Jun 10, 2008 | 07:28 PM
x0!'s Avatar
x0!
a new fuel pump and strainer should be a little under $100 at autozone/oreillys/advance
Old Jun 10, 2008 | 08:50 PM
Jimmy's Avatar
Global Moderator
Default Re: (x0!)
This is typical for a honda during the summer..
If your having issues with the fuel pump not wanting to turn on.. Near your hood release latch is your PGM-FI main relay.. it control's weither or not the fuel pump kicks on..
This is due to the soldier joints in the relay being dry and cracked.. If you know how to soldier.. You can remove the 10mm bolt holding the relay in.. Pull the grey cover off the relay and re soldier the joints..
read:
http://techauto.awardspace.com/mainrelay.html
Old Jun 12, 2008 | 12:19 PM
bimmeracer's Avatar
I changed the main relay the first time it did this and it stopped the problem for a while, but it happened again.
Old Jun 12, 2008 | 01:53 PM
Jimmy's Avatar
Global Moderator
Default Re: (bimmeracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bimmeracer &raquo;</TD></TR><TR><TD CLASS="quote">I changed the main relay the first time it did this and it stopped the problem for a while, but it happened again.</TD></TR></TABLE>
did you replace the relay with a new one or another used one..?
If so the joints could of been just as bad as the one you replaced it with..
Old Jun 13, 2008 | 05:03 PM
bimmeracer's Avatar
yea, it was another used one, but the car was in running condition.
Old Jun 13, 2008 | 06:14 PM
ke98248's Avatar
If you find it's the fuel pump, I have an extra stock fuel pump from 97 civic ex d16y8 I can give ya..
Old Jun 13, 2008 | 11:24 PM
badboyr66's Avatar
Default Re: (ke98248)
Good link posted... I noticed they listed three on there for main relays... can you mix and match? I have one from a 96 CRV to use in my 92 hatch
civic28
Mar 26, 2014 04:18 PM
ksbenjamin44
Jun 25, 2009 05:22 PM
datonefoo1
Feb 8, 2008 12:29 PM
94delsol6428
Dec 27, 2006 07:06 PM
