92mm crank in a b18c5 what rods length?
hi everyone. im looking at a crower 92mm crank i might want to buy for my itr block. i have a friend that used a 95mm crank in a gsr block and he had to use b16 rods. so im asking which rod length do i go with for the 92mm crank? thank you all.
You'd subtract half of the difference in stroke from the length of your stock rods, so you'd want 5.3355" rods. The closest stock rods would be LS rods, but if you used them you'd want to move the pins down in your pistons by .0585".
