B18B1+trans+ecu in to '92 CX Hatchback.
Old Jun 10, 2008 | 02:07 PM
socialistic's Avatar
Default B18B1+trans+ecu in to '92 CX Hatchback.
Did some searching, browsed the stickies, and found no clear info on swapping the running gear out of a 94LS in to a 92 CX. Maybe I looked over a link or something.
I have the 94LS parts car in my shop, and my buddy wants the motor+trans+ecu in his civic....
I'm going to safely assume that I leave the motor and trans intact, with harnesses, because it should all be a direct swap apart form having to mix-n-match a few motor mounts. ECU should be a direct swap as well. I will be keeping P/S, obviously no A/C. I also believe that I can re-use the b18b1's intermediate shaft and axles.
Is this swap pretty much plug-and-play apart from mixing the engine mounts? Do I use the Integra's shift linkage+shift stabilizer linkage+shifter? Is there other details or changes I need to make?
Thanks in advance to those who offer their advice/answers.
Modified by socialistic at 5:21 PM 6/10/2008
Old Jun 10, 2008 | 03:18 PM
CivicSpoon's Avatar
Integra driver's side mount & bracket, and the rear mount bracket. Then you use the rest of the Civic mounts. You are correct on the axles and intermediate shaft, as well as using the Integra shift linkage/etc. You could use either harness, but just make sure that the 4-wire O2 sensor is wired up, because all '92-'95 CX's (other than the California version) only had a 1-wire O2 sensor. The CX's also don't have P/S.
Old Jun 10, 2008 | 04:29 PM
So if I'm re-using the b1's engine harness and o2 sensor...I don't need to do any re-wiring?
Old Jun 10, 2008 | 05:27 PM
superfast666's Avatar
Default Re: (socialistic)
u wont be able to retain the power steering unless u get a power steering pump from a 99-2000 si b16 one
Old Jun 10, 2008 | 06:24 PM
Yah, I know the 92 CX doesn't have power steering...and I'm not sure why I said I'd be using it, haha.
I just need my las post answered, I'm fairly clear on the rest of the swap.
Old Jun 10, 2008 | 07:38 PM
95vxtealhatch's Avatar
I beleive you need to wire the 4 wire o2 sensor up. No vtec wire needed. correct me if i am wrong.
Old Jun 10, 2008 | 08:10 PM
CivicSpoon's Avatar
I seem to remember someone saying that the '92s are also prewired at the shock tower plug for a 4-wire O2 sensor, in addition to vtec. I personally don't know for sure.
Old Jun 10, 2008 | 10:03 PM
I will be re-using the b18b1's engine harness...it won't be removed from the motor at all during swap. I'd imagine the plug for the o2 sensor is on that harness...so do I just plug the o2 sensor into the harness like it is on the 94LS and call it a day, or is there wires that need to be pinned into the ecu harness plugs?
Old Jun 10, 2008 | 10:11 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by "CivicSpoon" &raquo;</TD></TR><TR><TD CLASS="quote">I seem to remember someone saying that the '92s are also prewired at the shock tower plug for a 4-wire O2 sensor, in addition to vtec. I personally don't know for sure. </TD></TR></TABLE>
I'll look in to that. Hopefully that's true because I have no idea where I would pin those 4 wires, if that is what I'd have to do.
Old Jun 10, 2008 | 11:57 PM
USDMCIVICHATCH's Avatar
it is a direct swap using everything from the Integra such as:
all the Integra mounts. you don't have to mix and match I don't know why someone told you that. however the tranny mount and rear mount are the same on both
complete Integra shift linkage
throttle cable
intermediate shaft and both axles
engine harness just plug it up at the shock towers
ecu
and other little bits like radiator hoses etc.
Old Jun 11, 2008 | 12:20 AM
Awesome, thanks.
If I run into any issues I'll post an update. Sounds like I don't need anything else, though.
WhiteOnRice
33
Oct 9, 2007 05:50 PM
jugodmyko
Mar 7, 2007 06:18 PM
itr0032
Sep 28, 2001 02:50 PM
