Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
2000 CRV low compression in #1
Old Jun 10, 2008 | 02:07 PM
1992Si's Avatar
Default 2000 CRV low compression in #1
A friend has this problem. engine has 72,000 miles.
Mechanic (trusted) did a leak down test and #1 loses I think she said 15% does that sound right?
The mechanic is getting a bor-o-scope late next week and will take a look and photo's inside. We'll wait until he can do that before I pull the head and have a valve job done on it.
I read in another post here that B20's have been known to burn exhaust valves.
Do you think that is what happened here?
Old Jun 14, 2008 | 01:59 PM
Hawkze_2.3's Avatar
Default Re: 2000 CRV low compression in #1 (1992Si)
I have also read about the burning exhaust valve issue. Did it ever have a valve adjustment in its 72K miles?
Old Jun 15, 2008 | 05:41 AM
1992Si's Avatar
I'm guessing no.
Old Jun 18, 2008 | 04:08 PM
vapor40's Avatar
I would start with checking the valve adjustment, just check it. If it is way out of spec then you will need to replace the head. There is a tsb.... although Im not sure if the 2000 model is in this tsb but I think it is. I will look and re-post.
B2R
Jul 31, 2018 08:53 AM
98integralsB18
Dec 30, 2010 05:17 AM
IH82LOSE
Jul 19, 2004 10:27 PM
EleanoR
Mar 24, 2002 06:51 AM
