VTEC PROBLEM
Old Jun 10, 2008 | 11:50 AM
Pleiadi79's Avatar
Default VTEC PROBLEM
hi guys.
i have a problem on vtec system on a B16A2. when i'm driving sometimes it enters at 5500 rpm and sometimes at 6500 rpm, but when in vtec the car don't seems to go better than no vtec zone.
which is the correct rpm range for vtec? tks
Old Jun 10, 2008 | 11:55 AM
DTA-Zombie's Avatar
what ecu are you on? do you hear vtec engage? for that car 5500-5800 should be about right.
Old Jun 10, 2008 | 12:11 PM
Pleiadi79's Avatar
Default Re: (DTA-Zombie)
i hear vtec enge but seems that engine dont "pushes"
the ecu is the original one with hondata module
Old Jun 10, 2008 | 01:17 PM
mitchell_2kSiR's Avatar
Default Re: (Pleiadi79)
my friend had the same problem, oil wasnt even touching the dip stick, throw some oil in there and maybe it will keep up the oil pressure to switch over to vtec? since then it has worked problem free
Old Jun 10, 2008 | 01:44 PM
DTA-Zombie's Avatar
if oil pressure is low it shouldn't engage - check oil pressure - are you throwing any codes?
Old Jun 12, 2008 | 08:22 AM
Pleiadi79's Avatar
problem solved! I was the solenoid connector not plugged in correctly now it engages at 5500 rpm
tks
JSpekBB4
Oct 30, 2007 10:23 PM
gsl_05
Mar 31, 2006 01:58 PM
salman
Mar 14, 2005 12:43 AM
zer0zer0 TypeR
Jun 6, 2002 04:53 AM
filetofit
Mar 27, 2002 08:38 PM
