4-1 Header or Cat-Back exhaust???
Which thing gives more power header or cat-back?? My euro-spec ITR has the stock 4-2-1 style header and a test pipe. So do you think I will gain more by fitting a 4-1 header OR a cat-back exhaust? Thanks guys!
The best is to do both, but start with the header and remove the first bottleneck of the stock B-pipe. You need an 2.5" testpipe/cat too....
The stock euro header is shitz....
So if I do I test pipe will it be ok?
I orderded the DC JDM 4-1 will I need any special hardware to fit it except a test pipe with a 2.5 inch flange??
Check this: https://honda-tech.com/zerothread?id=204632
