what size of tire?(16X7 rim)
ok got some enkie rz-5 16X7 with a 42mm+ offset
they will only be used in the summer as I have winter steelies and tires.
So what size of tire will work the best on the crx? its on a 89 Si stock suspension
205/45r16? 205/40r16?? any ideas?
Definatly go with the 45r, the 40's are soo rough you feel every pebble on the road and the handling characteristics are basically the same even the look of the low pro.
It's a ratio of the width of the tire.
Take the width of the tire (205mm for this example) and multiply that by 0.4 or 0.45 depending on which tire you choose. That will be your sidewall.
HuskerHybrid
Aug 26, 2005 06:58 PM
hondaracin24
Jun 22, 2005 05:05 PM
Batoutahell
20
Dec 22, 2002 07:58 AM
