having a issue with b18b into 98 ex.
Old Jun 10, 2008 | 09:03 AM
92boostedgsr's Avatar
Default having a issue with b18b into 98 ex.
I recently installed a b18b into my 98 ex.
car starts cold almost dies so i hold throttle till warms up.
start driving and engine is still boggy and runs like a bag till engine light comes on, then drives and holds idle fine.
idle is still high though, about 1600 rpm.
any ideas?
heres the catch, i have a cel but when i check for codes and cel stays on constant with jumper in the blue 2 pin under the dash...
obd2a-obd1 rywire jumper harness with p75, and rewired dizzy plugs for the obd1 dist.
Old Jun 10, 2008 | 07:59 PM
Default Re: having a issue with b18b into 98 ex. (92boostedgsr)
anyone?
so today i unplugged the map and car starts and runs fine 800 rpm...?
but eats gas lol no wonder.. but this is super odd to me, normally cars would die with map unplugged... wtf is it something to do with the rywire harness i'm missing?
i've tried everything, and thats why i'm here for questions..
Old Jun 11, 2008 | 01:40 PM
i see everyone has no idea...
Old Jun 12, 2008 | 09:12 AM
MeanGreenMachine's Avatar
whats the timing like? has it been touched? have you even checked the timing with a timing light to see if your off?
Old Jun 12, 2008 | 09:40 AM
gibsanez's Avatar
Default Re: having a issue with b18b into 98 ex. (MeanGreenMachine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MeanGreenMachine &raquo;</TD></TR><TR><TD CLASS="quote">whats the timing like? has it been touched? have you even checked the timing with a timing light to see if your off?</TD></TR></TABLE>
All the mechanical timing is perfect and the distributor wiring is fine as well.
Old Jun 12, 2008 | 11:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92boostedgs &raquo;</TD></TR><TR><TD CLASS="quote">
and rewired dizzy plugs for the obd1 dist.</TD></TR></TABLE>
have you went over and double checked the rewired dizzy plug and made sure it was correct? i read of a similar instance on another forum and the person did not have the dizzy rewired correctly like he thought...
Old Jun 12, 2008 | 11:53 AM
gibsanez's Avatar
Went over the distributor wiring twice, one wire at a time. All wires are soldered and taped. Even tried a different distributor. New plugs as well.
The car only seems to run poorly with the MAP plugged in.
Old Jun 12, 2008 | 12:42 PM
Default Re: having a issue with b18b into 98 ex. (gibsanez)
MAP as in map sensor?
Old Jun 12, 2008 | 12:54 PM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MeanGreenMachine &raquo;</TD></TR><TR><TD CLASS="quote">MAP as in map sensor?</TD></TR></TABLE>
yep
Old Jun 12, 2008 | 04:01 PM
could you have mistakenly have mixed up the tps and map sensor plugs?
as in had the tps plugged into the map sensor, and the map sensor plug, plugged into the tps sensor....
Old Jun 12, 2008 | 04:23 PM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MeanGreenMachine &raquo;</TD></TR><TR><TD CLASS="quote">could you have mistakenly have mixed up the tps and map sensor plugs?
as in had the tps plugged into the map sensor, and the map sensor plug, plugged into the tps sensor....</TD></TR></TABLE>
No. The tps sensor will not reach the map sensor because it's loomed too closely to the IACV plug on the stock engine harness.
Old Jun 12, 2008 | 05:31 PM
im assuming you are using the 98 civic ex, obd2a engine harness?
what are your grounds like? grounds as in ground wires, are they where they should be?
EX: tranny to frame, rad core support to the valve cover, etc etc
Old Jun 14, 2008 | 06:52 AM
yes i have to reuse the 98 ex harness as it is a one piece harness..
all grounds were cleaned up as swap went in to avoid any problems.
Old Jun 15, 2008 | 01:18 PM
problem fixed.
traced back the map wiring to the ecu, problem was 2 wires reversed on the jumper.
ReSpade
10
Jun 3, 2016 08:16 PM
uvamosk
Dec 7, 2011 05:49 PM
nivEK99coupe
Nov 4, 2011 08:28 AM
shutupkid
Jan 28, 2011 02:05 PM
lsturbo*
Jan 8, 2009 03:38 PM
