bogging from the start
Old Jun 10, 2008 | 07:04 AM
radicaled434's Avatar
Default bogging from the start
when i first start my car its fine no problems, after its been running for a while and i sitting at a stop sign and i want to pull out into fast moving traffic my car thinks its funny to not go anywhere for the first 3000rmps and go from 0-20 in like 5mins before it takes off. its always doin this, i cant figure out whats wrong ive tryed alot
97 civic ex auto
Old Jun 10, 2008 | 07:47 AM
kay_animation's Avatar
Default Re: bogging from the start (radicaled434)
Could be a few things. Basically it's hesitation correct? Lumpy like rpm sounds?
I had a problem that was close to this. It's usually something ignition related. I suspected a rare problem of an injector going bad. I was pulling my plugs/wires out just to double check and saw that my #1 plug had oil in it. Turns out my valve cover seal was letting oil leak into the #1 plug cylinder and causing the spark to transfer from the plug. Resealed the valve cover and cleaned up the plug hole and problem solved. Though I do need to get new plug wires now since I'm sure the wire needs to be replaced from being soaked.
But I'd check spark plugs, spark plug wires, distributor (housing and rotor), and see if you find anything in those.
Old Jun 10, 2008 | 03:43 PM
Default Re: bogging from the start (kay_animation)
well when the car is in first gear and i go to take off it moves slow as anything untill it hits 3000rpms then it starts to move. after that its fine untill i slow down again
Old Jun 10, 2008 | 03:51 PM
Kyoh's Avatar
Check your cam timing. My car was doing the same ****. Bogging till 3000 then as soon as it got to 3000 it would take off. Turned out my cam jumped a tooth.
Bezoar
May 11, 2018 02:35 PM
crashsvg
Dec 1, 2008 05:51 PM
HTn00b
43
Nov 8, 2006 02:35 PM
Michler
Apr 17, 2006 06:59 PM
mugenpwr17
Jul 21, 2003 10:34 AM
