swaybar=oversteer + tearing?
Old Jun 10, 2008 | 12:49 AM
ekinshuya's Avatar
Default swaybar=oversteer + tearing?
guys i have a 98 civic hatch DX and i am thinking of geting ASR Subframe brace with Type R 22mm sway bar, along with blox endlink and OEM bushing. I DONT HAVE FRONT Sway bar so will this make the car OverSTEER alot? and also will it cause tear on the chassis?
Btw i have Buddy Club Coilover (8k front 6k rear i think)
Old Jun 10, 2008 | 01:18 AM
mormonboy's Avatar
Default Re: swaybar=oversteer + tearing? (ekinshuya)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekinshuya &raquo;</TD></TR><TR><TD CLASS="quote">guys i have a 98 civic hatch DX and i am thinking of geting ASR Subframe brace with Type R 22mm sway bar, along with blox endlink and OEM bushing. I DONT HAVE FRONT Sway bar so will this make the car OverSTEER alot? and also will it cause tear on the chassis?
Btw i have Buddy Club Coilover (8k front 6k rear i think)</TD></TR></TABLE>
you don't seem to know what the purpose of a rear sway bar is. if you don't know what your doing with it, youll most likely end up spinning out and hurting yourself or even someone else.
Old Jun 10, 2008 | 01:29 AM
Dutch_Mofo's Avatar
Don't know if the change is radical, but you will probably have more oversteer. I think more than just a bit.
Modified by Dutch_Mofo at 2:49 AM 6/10/2008
Old Jun 10, 2008 | 03:27 AM
instructor74's Avatar
Default Re: swaybar=oversteer + tearing? (Dutch_Mofo)
You really need to get a front sway bar on the car before you worry about putting a 22mm rear sway bar on the car. You are going to really upset the balance on the car and cause handling issues not limited to oversteer
Old Jun 10, 2008 | 06:23 AM
count me out's Avatar
* B A N N E D *
the car will be un[freak]ingdrivable with an itr in the rear and nothing up front. your *** end will be all over the place.
Old Jun 10, 2008 | 02:35 PM
mormonboy's Avatar
Default Re: (count me out)
ive got a ITR 22mm rear sway and no front sway on my 97' Hatch.
but i also did lots of research before actually going in for the purchase.
the handling changes quite a bit, and you have to readjust your driving habits (ie. braking around a corner = no no) etc.
but the OP clearly has no idea what the use of a rear sway is for, nor does he know what oversteer is or what causes it.
Old Jun 10, 2008 | 07:38 PM
ekinshuya's Avatar
nah i know the swarbar will cause oversteer, but i was planning to do the rear first since my bushing are bad and so might as well do the rear in 1 shot. I'll do the front too to balance it out, prolly a Si front sway bar or so. But yea i asked cuz i want to know if it will be really bad on the oversteer
Modified by ekinshuya at 8:43 PM 6/10/2008
ekinshuya
May 31, 2009 07:36 AM
ekinshuya
Suspension & Brakes
12
Jun 16, 2008 04:19 PM
MrXclusivE
Suspension & Brakes
Apr 17, 2008 06:53 AM
turboteg2nv
17
Jan 8, 2008 04:26 AM
GloomyX
Suspension & Brakes
18
Mar 29, 2007 07:42 AM
