What fuel injector to use on my lsv setup im building
I am pretty new to the lsvtec scene. But I am tryin to decide on a decent sized plug n' play injector for my car.
The person I bought the car from had an lsv but it broke so im rebuilding it.
It had stock injectors on it w/o an adjustable fuel pressure regulator. It has a gsr head with the b18b block. I am runnin ~12.1 compression pistons with eagle rods. I am going to be using the skunk2 pro1 cams. I have a 255lph fuel pump now. But I would like some advice to go by to start searching for some good sized fuel injectors. any help would be great!
i would run at the minimum some 310's. maybe get some bigger injectors just in case your setup changes down the road.
What are you making for power any idea? If so do the math:
<U>HP x BSFC (.5 for NA)</U> = lbs per hour
4 (# of injectors) x duty cycle %
Lbs per hour x 10.5 = CC per min
a simple answer would be to visit RC's site and take a look at their calculators and make an educated decision off there...
they have b.f.s.c., hp/cyl. numbers, etc...its a really good starting point to educate yourself with the necessary calculations for fueling requirements
JDM turbo DC
Mar 24, 2006 05:44 PM
