question on my springs
well i got neuspeed springs...and they dont drop my car enought, but the front is droped great, but the back hs so much fender gap. and i got 2 coil overs, so i was wondering if can take the front springs and put them in my back wheels,and the coilovers in the front?? will the spring work in the back???
They should fit, but you have to remember that the front has much more weight than the back. If you put stiff springs in the back they are going to still sit pretty high because there is not that much weight to lower them. You can try it and see where the drop is. Also with stiffer springs in the back you're going to have more of a tendency to oversteer. That's assuming of course the the springs you put in the front will be softer than the ones you put in the back. But I'm not sure how stiff the coilover springs you have are.
JaimmyACA
Nov 26, 2011 09:46 PM
