Timing?
Is it possible for your timing belt to stretch( over time ) and throw your timing out.
Reson I ask is when I turn the car over in the morning most of the time the car turns on the second attempt.
Its been doing this for a while now. If I can turn the car over on the firts attempt it drive good ( pulls well threw the gears) if its on the second attempt the pull is weak. Ive done a full tune up and its still the same.
Could it be the timing belt. Had the CRX for 6 years.(long story, post it some day) Only drive it 5 months out of the year.
Thankz in ADV.
Thankz in ADV.
The timing belt could definitely come loose over time. The 1st 2nd startup thing is weird however. If it jumps a tooth it not gonna jump back so easily. Sounds like a sensor or comp problem. Any codes??
So I go to the mechanic today and find my front window is broken. I ask him what happened And he has no Idea what happened
to make matters worse I drive the car home and find the engine makes a winding noise. ( is that normal for a timing belt change?)
Im so
I don't know what to do.
Im so
I don't know what to do.Thread
