white smoke from valve cover and rough idle
Old Jun 9, 2008 | 05:44 PM
all_motorsi's Avatar
Default white smoke from valve cover and rough idle
My engine is a stock block Boosted B16a, I was running a built D16y8 turbo coupe and beat him by 3 cars 1st to 3rd gear. when i came to the next light i noticed smoke from under the hood, I popped it and saw alot of white oil smelling smoke from the valve cover breather, and the car idles like it has a misfire but runs fine otherwise. I'm thinking rings/ ring lands?
Old Jun 9, 2008 | 06:05 PM
vtecb18c's Avatar
Default Re: white smoke from valve cover and rough idle (all_motorsi)
pull a compression test and check your valve seals and valve cover gasket
ck123
12
Jul 21, 2006 07:57 AM
Liquidgsr
Mar 12, 2005 03:22 PM
el3vate
Nov 27, 2004 10:34 AM
SSR'd
Feb 8, 2004 05:46 AM
