b16 not starting after upgraded cams? Please look, weird problem...
Old Jun 9, 2008 | 05:31 PM
91EF_Si's Avatar
Default b16 not starting after upgraded cams? Please look, weird problem...
I just bought a 91 crx with a jdm b16a, 450 injectors, cp high comp pistons, port and polished head, shaved for higher compression, aftermarket springs and retainers, and skunk 2 stage 2 cams. Running obd1, no CEL.
When I first got it, I had to press the gas and let it crank for about 10 seconds then it starts. If it didn't start that way, I will have to disconnect the coolant temp sensor and it will start. I've already changed it twice and still the same. So I tough it was a timing isuse and I re-time it a few times to TDC, how it previously was. Now it won't start at all unless I push start it? Plus it won't stay idle, if I let off the gas it will stall.
Previous owner/builder said it was street tuned by Chrome for ITR cams, and he saids after he put in the new cams it's been acting up. Might I need a new tune? Or can I put in ITR cams and see what happens? Please help, only car I got.
Modified by 91EF_Si at 6:57 PM 6/9/2008
Old Jun 9, 2008 | 05:36 PM
91EF_Si's Avatar
Default Re: b16 not starting after upgraded cams? Please look, weird problem... (91EF_Si)
Oh yea, and when I crank it over it won't start but smells like gas. But no gas leaks.
Old Jun 9, 2008 | 10:35 PM
91EF_Si's Avatar
Old Jun 10, 2008 | 07:06 AM
91EF_Si's Avatar
anyone?
Old Jun 10, 2008 | 08:23 AM
DTA-Zombie's Avatar
could be something with distributor/wires but could use a new tune with cams changed. I haven't heard of anyone having issues with 450's
lots of variables on this.
1junkycivic
Dec 27, 2008 11:19 PM
91EF_Si
17
Jun 10, 2008 10:31 AM
b20izzle
Apr 18, 2006 04:41 PM
seako_916
May 10, 2004 07:37 PM
