b16 not starting after upgraded cams? Please look, weird problem...
Old Jun 9, 2008 | 05:31 PM
91EF_Si's Avatar
Default b16 not starting after upgraded cams? Please look, weird problem...
I just bought a 91 crx with a jdm b16a, 450 injectors, cp high comp pistons, port and polished head, shaved for higher compression, aftermarket springs and retainers, and skunk 2 stage 2 cams. Running obd1, no CEL.
When I first got it, I had to press the gas and let it crank for about 10 seconds then it starts. If it didn't start that way, I will have to disconnect the coolant temp sensor and it will start. I've already changed it twice and still the same. So I tough it was a timing isuse and I re-time it a few times to TDC, how it previously was. Now it won't start at all unless I push start it? Plus it won't stay idle, if I let off the gas it will stall.
Previous owner/builder said it was street tuned by Chrome for ITR cams, and he saids after he put in the new cams it's been acting up. Might I need a new tune? Or can I put in ITR cams and see what happens? Please help, only car I got.
Modified by 91EF_Si at 6:57 PM 6/9/2008
Old Jun 9, 2008 | 05:36 PM
91EF_Si's Avatar
Default Re: b16 not starting after upgraded cams? Please look, weird problem... (91EF_Si)
Oh yea, and when I crank it over it won't start but smells like gas. But no gas leaks.
Old Jun 9, 2008 | 06:09 PM
2LEM1's Avatar
I like to party
Community Builder
Community Influencer
You need bigger injectors. Try 1000s.
Oh ya, Try tuning it.
Old Jun 9, 2008 | 10:34 PM
91EF_Si's Avatar
Default Re: b16 not starting after upgraded cams? Please look, weird problem... (2LEM1)
I know these injectors are too big for this setup, but they were tuned for the setup. I've tried stock injectors and stock ECU, still the same thing.
Old Jun 10, 2008 | 07:04 AM
91EF_Si's Avatar
anyone?
Old Jun 10, 2008 | 07:28 AM
h22crxpwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91EF_Si &raquo;</TD></TR><TR><TD CLASS="quote">anyone?</TD></TR></TABLE>
you prob just need a retune. put it on the dyno and tune it.
Old Jun 10, 2008 | 07:43 AM
Boots's Avatar
Default Re: b16 not starting after upgraded cams? Please look, weird problem... (h22crxpwr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22crxpwr &raquo;</TD></TR><TR><TD CLASS="quote">
you prob just need a retune. put it on the dyno and tune it. </TD></TR></TABLE>
like he said...your timing is probably off...and that gas smell, everytime you crank, the injectors fire, so you're probably flooding it
Old Jun 10, 2008 | 07:52 AM
91EF_Si's Avatar
Default Re: b16 not starting after upgraded cams? Please look, weird problem... (boots)
So why would it smell like gas with the stock injectors too? Should I retard/advance my cam gears?
Old Jun 10, 2008 | 07:53 AM
2LEM1's Avatar
I like to party
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91EF_Si &raquo;</TD></TR><TR><TD CLASS="quote">So why would it smell like gas with the stock injectors too? Should I retard/advance my cam gears?</TD></TR></TABLE>
NO, you should take it to a dyno and get it tuned. Christ, is this NEW information to you guys?!?!?!
Old Jun 10, 2008 | 08:02 AM
91EF_Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2LEM1 &raquo;</TD></TR><TR><TD CLASS="quote">
NO, you should take it to a dyno and get it tuned. Christ, is this NEW information to you guys?!?!?!</TD></TR></TABLE>
I just don't want to spend all this money on tunning it, and it doesn't fix my problem. Just trying to get info, ok.
Old Jun 10, 2008 | 08:07 AM
2LEM1's Avatar
I like to party
Community Builder
I just don't want to spend all this money on tunning it, and it doesn't fix my problem. Just trying to get info, ok. </TD></TR></TABLE>
Here's your info - TUNE IT ON A DYNO.
Old Jun 10, 2008 | 09:01 AM
h22crxpwr's Avatar
then swap back to stock cams and see if it runs better.. if it doesnt then you have another problem..
if it does run the way it should with the stock cams then put the skunk 2 cams back in and tune it....
and do a tune up on it.. new plugs, wires, cap, rotor, fuel filter.. etc.. u might as well. i'm sure those plugs are beat.
Old Jun 10, 2008 | 09:37 AM
91EF_Si's Avatar
They were, I changed them yesterday.
I push started the car and drove it around the block, and like it always it wants to stall..and I noticed it has no power under 3k, like its bogging bad.
Old Jun 10, 2008 | 09:43 AM
h22crxpwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91EF_Si &raquo;</TD></TR><TR><TD CLASS="quote">They were, I changed them yesterday.
I push started the car and drove it around the block, and like it always it wants to stall..and I noticed it has no power under 3k, like its bogging bad.</TD></TR></TABLE>
like i said it sounds like it needs a tune. you are running pretty big injectors with big cams.. you need a tune. but to be sure its the cams you can switch back to the stock cams and see if it runs fine..
even switching back to stock injectors with the same tune could make it run like garbage. if its tuned for stock cams and 450cc injectors!!!
regardless of what you do you are going to need a tune.. unless you want to have a blown up motor... running too rich or too lean is a recipe for engine failure...
Expensive failure..
Good luck!
Old Jun 10, 2008 | 09:50 AM
91EF_Si's Avatar
Thanks for the info man. I will get it tuned this week, and will post how it went.
Old Jun 10, 2008 | 09:57 AM
h22crxpwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91EF_Si &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for the info man. I will get it tuned this week, and will post how it went.</TD></TR></TABLE>
cool. good luck.. i wouldn't drive it until you get it tuned... driving it like that can hurt it even more...
and take a spare set of sparkplugs to the dyno with you. better to have them on hand if you need them. be prepared.. make sure you have no leaks or anything that will make them stop the dyno.. it would suck to have to pay and not even get to tune...
good luck and post up the results...
Old Jun 10, 2008 | 10:25 AM
SkoundrelUSA's Avatar
cute little bastard
Valve adjustment?
Old Jun 10, 2008 | 10:31 AM
OEM1's Avatar
Default Re: b16 not starting after upgraded cams? Please look, weird problem... (SkoundrelUSA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA &raquo;</TD></TR><TR><TD CLASS="quote">Valve adjustment?</TD></TR></TABLE>
x1000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 00000000000000000000000000000000000000000000000000 0000
1junkycivic
Dec 27, 2008 11:19 PM
91EF_Si
Jun 10, 2008 08:23 AM
b20izzle
Apr 18, 2006 04:41 PM
seako_916
May 10, 2004 07:37 PM
