Ls Swap in my CRX Hf what harness to use
Old Jun 9, 2008 | 03:03 PM
Jackson_Si's Avatar
Default Ls Swap in my CRX Hf what harness to use
i just got my ls in my hf and used the ls harness and i have no spark and im told by hasport to use the stock hf harness im pretty confused now i have the pr4 ecu in there some one please help
Old Jun 9, 2008 | 04:11 PM
89hatcher's Avatar
yes use the stock hf harness...is it still obd-0?
Old Jun 9, 2008 | 04:42 PM
Jackson_Si's Avatar
Default Re: (89hatcher)
yeah still obd0 what ecu do i use
Old Jun 9, 2008 | 04:49 PM
Loaded Butane's Avatar
Default Re: (Jackson_Si)
You use the hf harness and a obd0 pr4 from a manual teg.
Old Jun 9, 2008 | 04:53 PM
jlicrx's Avatar
OBD0 PR4 from 90-91 Integra LS - you need to use the HF harness because of the wire loctions in the connectors - for instance, the HF has the igniter wire in the driver's side connector, where the Si and LS have the igniter wire in the passenger side connector - in the HF harness driver's side connector, only one wire is in the same location (in the connector) as the wires in the Si or LS connectors
Jackson_Si's Avatar
Default Re: (Loaded Butane)
k so put the hf harness back in run my pr4 anything else
Old Jun 9, 2008 | 04:56 PM
Jackson_Si's Avatar
Default Re: (jlicrx)
k thanks i will try that i hope thats it thanks for the help
Old Jun 9, 2008 | 05:00 PM
jlicrx's Avatar
you should have one connector on the HF harness that you won't need - it was for the EGR valve
Old Jun 9, 2008 | 05:03 PM
Jackson_Si's Avatar
k well i will et u know how its works thank s
Old Jun 10, 2008 | 04:12 PM
Jackson_Si's Avatar
car fired up 1st try thanks everyone
Old Jun 19, 2008 | 08:20 AM
92nahatch's Avatar
ok so i have jacksons hf in my crx still obd0 and i need to know how to convert the ls harness to work with the hf motor. if someone has a diagram or a link to a diagram so i can repin this harness so i can drive this slow pos
Old Jun 19, 2008 | 08:29 AM
92nahatch's Avatar
Default Re: (92nahatch)
would it be easyer to just get a crx harness and wire in a egr valve????
92nahatch
Jul 7, 2008 05:37 PM
ITSTOCK
Nov 15, 2003 03:51 PM
Serdar
Aug 15, 2003 08:05 PM
pdiddyparsons
Mar 26, 2003 05:13 PM
CimorelliCRX
Apr 18, 2002 02:14 AM
