idle like no one elses help
Old Jun 9, 2008 | 10:36 AM
teamXteg's Avatar
Default idle like no one elses help
ok my car idle fine when its cold but soon as it warms up it drops down to like 497-517 i have a apexi vtec controller so i can see the idle but if u get on it a lil bit and go past 5k rpms it will start to idle hop between 1k-2k but if u shut off the car and turn it back on real quick its like it resets it. i have cleaned out the iacv and took out the idle fuse. adjusted the tps and the distributor and i get nothin messed wit the idle screw but i doesnt help wit the idle hop or nethin any help i would b greatful thanks guys
Old Jun 11, 2008 | 11:45 PM
swade's Avatar
Default Re: idle like no one elses help (teamXteg)
Bump... anyone know
swade
Old Jun 12, 2008 | 09:44 AM
mayoforlife2's Avatar
Default Re: idle like no one elses help (swade)
when the idle is jumping up and down , take your intake tube off, and try to plug the hole in the throttle body that goes to the iacv with you finger , if the idle is better after that then you could do it the way i always to and take a piece of aluminim (spelling?) from a soda can and block that off by taking the iacv off. try that?
Old Jun 13, 2008 | 11:08 PM
teamXteg's Avatar
Default Re: idle like no one elses help (mayoforlife2)
ok man cool ill give that a shot thanks
Kid-jdm-teggy
May 13, 2013 12:06 PM
92_JDM
Engine Management and Tuning
Aug 12, 2010 03:23 PM
blackZC (W)
Jun 21, 2004 05:58 AM
killa_lude
Aug 16, 2003 08:33 AM
