Wheel bearing
Old Jun 8, 2008 | 07:54 PM
DACteg's Avatar
Default Wheel bearing
So i was putting my new rotors on, and noticed i had a little play in my front wheel bearing.
Anyone know what wheel bearing i need to buy for a 91 GS integra, it had ABS, but i dont use ABS anymore. will a 92-95 civic one fit it? i see them all over, but no DA integra ones.
Thanks.
Old Jun 9, 2008 | 11:25 AM
God-Driven's Avatar
make sure the play is comming from the hub bearing and not the outher or inner tie rods, I dont think the civic bearing will fit but the hub bearing is the same for ABS system and non ABS, just get one from oreillys or auto zone they run from 70 to 80 dollars plus if you dont have a hydro press you are going at have to pay a local shop to press the old one out and the new one in, dont try to hammer it.
Old Jun 9, 2008 | 07:29 PM
bigkvn77's Avatar
Default Re: Wheel bearing (DACteg)
God driven is "Right" Make sure its not your suspension parts (tie rods, ball joints) Usually if your wheel bearing has play there is also alot of noise associated with it too. The abs ring is on the axle so the wheel bearing has nothing to do with the abs. Both bearings are the same size just as stated by god. Just purchase the proper bearing if that is the case and replace it. They are a true pain in the rear. GL
B_Swapped93
Suspension & Brakes
Sep 28, 2018 07:52 AM
jason_SIR
Mar 25, 2014 01:49 PM
WRTEG
Apr 28, 2005 03:04 PM
alexdog69
Oct 18, 2004 02:43 AM
