Difference Between zc cams and d16a9
Old Jun 8, 2008 | 07:16 PM
GLI's Avatar
GLI
Default Difference Between zc cams and d16a9
I would like to the know the differences, if there are any, between these two camshafts so I could buy replacements for my doch zc. Thanks.
Old Jun 8, 2008 | 07:50 PM
ponchdriver16's Avatar
Default Re: Difference Between zc cams and d16a9 (GLI)
d16a9 cams have less lift and duration than zc cams. if you put them in, your car will run like poop. if your cams are b**ched up and you cant use them as is, send em out to webcamshafts.com or JGEngineering as regrinds and make em better. if you dont have cams at all.........good luck. check on thezcr.com for more info.
Old Jun 8, 2008 | 07:59 PM
GLI's Avatar
GLI
Ok thanks. Anyone else have any other options out there for people looking for different cams to put into there zc's?
Old Jun 15, 2008 | 05:20 AM
~sp33~'s Avatar
EFB055
Default Re: Difference Between zc cams and d16a9 (ponchdriver16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ponchdriver16 &raquo;</TD></TR><TR><TD CLASS="quote">d16a9 cams have less lift and duration than zc cams.</TD></TR></TABLE>
Less lift and duration, but more power?
It was my understanding that the differences between the d16a9 and the ZC where just different emission regulations.
Old Jun 15, 2008 | 03:29 PM
bobjohnson's Avatar
Default Re: Difference Between zc cams and d16a9 (~sp33~)
Youre reading it backwards. The ZC cams have more lift and duration. As far as i know, this is true. Its about the only real difference between a ZC engine and a D engine.
Old Jun 15, 2008 | 06:20 PM
88Hatchy's Avatar
Default Re: (GLI)
http://www.gude.com/Cams/cam_acura.html
Old Jun 15, 2008 | 07:31 PM
~sp33~'s Avatar
EFB055
Default FV-QR
Why does the d16a9 make more power then?
Old Jun 16, 2008 | 12:38 AM
generalBEEEF's Avatar
Default Re: FV-QR (~sp33~)
d16a9 was rated at 130... and was rated without a catalytic converter.
d16a8 is identical, but rated at 124... WITH a cat.
dohc zc is rated at about the same... 135 with the brown top, 130ish with the black... when it comes down to it, 5 crank horsepower isn't going to kill you.
Old Jun 16, 2008 | 06:57 AM
~sp33~'s Avatar
EFB055
Default Re: FV-QR (generalBEEEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by generalBEEEF &raquo;</TD></TR><TR><TD CLASS="quote">d16a9 was rated at 130... and was rated without a catalytic converter.
dohc zc is rated at about the same... 135 with the brown top, 130ish with the black... when it comes down to it, 5 crank horsepower isn't going to kill you.</TD></TR></TABLE>
135?! The brown top was superseded by the black top. It was old and im pretty sure it was only good for no more then 120hp if that.
Slomo_civic
Sep 10, 2005 12:28 PM
89 pos
Mar 27, 2005 11:56 AM
FBPninetynineEM1
Jan 26, 2003 12:48 AM
88' CRX ZC
Mar 6, 2002 08:12 PM
Hondasaurs
Oct 31, 2001 08:06 AM
