K-Pro question (do all PRB ecus work?)
My buddy is selling a 04 RSX-S ecu, code number: 37820-PRB-A06. Im looking to buy it to do K-Pro on my S2000. But i have a simple question. Do all 02-04 RSX-S ecus work for Kpro? On the Hondata website is says: "All user supplied ecu's must be PRB A01-A12 and in perfect working order. We will not use any other ecu's for the S2000."
The way it is worded it could be taken two ways. Either ecu number A01 through A12 could be used, or only A01 and A12 can be used.
Any input?
Any input?
All PRB Ecu's will work but I would try to follow their parameters since you dont want to spend teh money on an ECu for them to return it to you. Your buddies ECU will work and falls under their paramenters so you will be ok
basiceg6
Nov 27, 2009 09:45 AM
