crx/gsr question
so i just got my friends crx runnin we installed a gsr
the only prob we are havin is it keeps shuttin off if the car is sitten at a idle and you tap the gas peddle reapetivley it will die wen he comes to a light it idles fine till he goes for take off it will die b4 he realeses the clutch engine light comes on wen it dies but theres only a solid light please help ht tryen to get this runnin b4 giffith park meet
thanks H-T
thanks H-T
is the CEL on? why are you tapping the gas so many times, so fast? i don't know anyone that does that...you are probably tricking the ecu into thinking there is a problem, with the tps, o2 sensor or whatever. rev it normally and what does it do?
its fine wen i rev it the reason i did it cause i was tryen to c if it would die but it does wen you leave a light just givin it regular throttle but the cel is just solid then wen it dies it takes a few trys to start it
my b18c1 ef had similar problems. it was really intermitten but everynow and then while i would accelerate moderately, it studdered bad. it seemed like fuel cut or a rev limit, but it was never at a consistant rpm. sometimes it ran fine, other times it studdered and ran like crap.
even sometimes the CEL would light up dimly and brightened up proportionally with the throttle angle, all accompanied by the studdering. i used good wiring conversion kits. basically a p28 on a p72 basemap. its originally a p06 so no KS or IABs, which i run a skunk2 intake manifold.
i'd really like to know too. anybody?
i've tried that. i even swapped throttle bodies with one i had laying around. still the same thing. besides, wouldn't driving your car without a tps create other symptoms that aren't even related to the real problem? i swapped ecu's, dizzy's, cleaned and tightened all the grounds. even made more grounds. it still does the same ****.
i'm stumped. also, another symptom. when i turn the ignition to "ON" the fuel pump does not prime. when i unplug the IACV, then pump primes instantly. i swapped IACVs off my brother's teg, which i know works, and i still have the same symptom. i dunno what the hell's going on. what else can i check. everything else is fine. i mean the ignition is in time, compression is good, timing is good. what else do i check?
yo. i know wut the problem is. the driver is a monkey and the retard tryin to fix it is Trex and his foot is [freak]in up the throttle. thats all. just have a normal person drive it. or stop stalling and then blaming it on the car. lol!!
nah jk, these are my homies...but for real...the problem was inside the distributor ...the screw that holds on the rotor was completely backed out!!! now the car starts and stays on all the time!!!
who woulda thought!
anyways...its rippin now! good **** e1
who woulda thought!
SupraRXZ
18
Dec 1, 2007 10:51 AM
BxCrx91
31
Oct 2, 2005 04:34 PM
