idle rpm?
Old Jul 16, 2002 | 09:16 PM
BYT's Avatar
BYT
Default idle rpm?
hey guys i'm just wondering what the normal idle rpm should be. i've got a 92si with the d16z6. when i come to a stop sometimes the idle will drop to around 100 rpm and the car vibrates but never stalls out. is this normal? what do you guys idle at?
Old Jul 16, 2002 | 09:27 PM
97hb's Avatar
Default Re: idle rpm? (BYT)
I idle at 800 +- 50. Yours should be about the same.
Old Jul 16, 2002 | 09:29 PM
nwdave's Avatar
Default Re: idle rpm? (97hb)
That bottom line on your tach is 500, not 100. So you're probably idling about 600 or so. That's happened to me in my old car, and I've heard it's fairly common. Not sure what the cause is, but I know it's not like, life-threatening.
Old Jul 16, 2002 | 09:37 PM
BYT's Avatar
BYT
Default Re: idle rpm? (delsolguy)
haha my bad i guess around 500 then. i've read stuff about the iac getting clogged? could this be a possibility? i know that if i just slightly hold the throttle it smooths out. is there a screw somewhere that i can use to adjust the idle?
JDM_SOHC
27
May 13, 2013 05:09 PM
turbotime
Oct 24, 2005 12:01 PM
REDMAN1322
Sep 1, 2001 01:29 PM
