h22 to f22 swap?
ok so i have a 93 civic with a h22a4 and the motor is blown, i just bought a 94 f22b1 sohc vtec and am goin to swap it into the civic, i already know that my motor mounts, tranny, clutch/flywheel can be swapped from the h22 to the f22. what i dont know is if the wiring is goin to be the same, am pretty sure a lot of it will work. does anyone know anything about this swap..
thnks
thnks
there is another two wires at the ecu that has to be swapped back. when the h22a was installed they were swapped.
i forget which ones they were of course but i learned this the hard way when i had a h22 in my accord that i put back to f22 to sell and i ended up selling it with a CEL because i didnt swap the two wires.
What 2 wires?? I havn't had to swap any wires at the ecu when swapping an H22 into a civic??
the H22 and the F22 dont use the same mounts.. how ever why are you swaping an Fseries in a civic? it doesnt make sence to me.. what harness are you using the H22 or F22?
the f22 and h22 are the same mounts, i did this same "swap back" about 9 years ago when my H22 spun a bearing. i used my same wire harness as i used for the H. i never had a problem at all except the fact the F22 sucked *****.
ah..i got goofed..OP said f22B not f22A. carry on
matix
Sep 25, 2003 06:18 AM
