del sol makes loud rattling noise inside cabin.
the sound is coming from my roof. when i take the roof off the car stops rattling but when its on I hear constant LOUD rattling all the time. Do any of you experience this? If so, what are some ways for me to fix this issue? Is there somethign I can do to minimize the noise?
Thanks,
androO
Thanks,
androO
you can try some silicone grease on your seals, that should puff them up a bit and make your roof fit tighter. Do it a few times over a week, and it should help a bit.
If its pre 95, you may conceder getting 95+ front roof seals, they seal better than the older ones.
But I only read that, I haven't changed mine yet, but I did get less noise, and water leaks once I started using the silicone.
Good luck.
Good luck.
If you take off the plastic panels there is a push rod mechanism in there, there might be a lose bolt ect. causing your rattling noise.
okay i'll try to take apart the hood and see what i can do to repair it. where can i get new seals from? the seals are those rubber things on the edges of the targa top right?
thanks
thanks
nah its definately not the sun visor. i took apart the whole roof this morning and added additional material to absorb any vibration. then i screwed everything a bit tighter.
I put the top back on and i still get noise so i'm thinking maybe its something thats on my car thats making the rattling. maybe its not holding hte hood in place good enough?
mdozier7180
Dec 9, 2014 11:37 AM
