crankshaft bolt removal
I just bought a 01 civic. I wanted to change the timing belt. How the hell do you get the crank pulley bolt out. Holy hell 181ft lbs. the manual says! My impact doesn't touch it and I broke my strap wrench trying to hold the pulley. Is there a secret?
Honda wanted $87.00 for the tool, I checked e-bay and found Kd tools sells the holder part number 3970. This place sells it for $35.00.
http://www.aimsupply.com/Home/....aspx
What else am I going to need for this job? Water pump gasket,or anything else? I was thinking maybe I should change the water pump too. Its got 99,000 miles. Any thoughts? thanks..
yea, you always want to change the water pump while you're there. you also want to replace the timing belt tensioner. and since you'll be removing the valve cover, it wouldn't be a bad idea to get a new gasket. There are also 2 o-rings that go on the water pipe that runs behind the block. Boilermaker and I have seen those leak..NEW, so you know they're weak. and one end of said tube goes into the water pump.
HatchBlakKidd
May 30, 2011 07:14 PM
