96 LS runs hot when idling for extended time.
Old Jun 7, 2008 | 06:50 PM
integrawow's Avatar
Default 96 LS runs hot when idling for extended time.
First off, this car is bone stock.
My car runs awesome when driving around or when at a red light for a short period of time. However, when I let it set and idle for about one minute, the temperature will start to rise. In order for it to stop climbing, i'll throttle the engine once or twice and the temperature will begin to go back to its happy place. It only happens when idling for extended periods of time.
I replaced the thermostat just for the hell of it without any results. I don't know why I replaced the thermostat. I guess my excuse could be that it's for maintenance LOL. Yes, i've checked the water level. LOL
Let me know.
Old Jun 7, 2008 | 07:00 PM
integrawow's Avatar
Default Re: 96 LS runs hot when idling for extended time. (integrawow)
I wanted to restress the fact that this car is bone stock. No modifications at all.
Old Jun 7, 2008 | 07:23 PM
LS-V_T_fullrace_EG's Avatar
possible head gasket or bad temp sensor... maybe clogged radiator
Old Jun 7, 2008 | 07:27 PM
integrawow's Avatar
Oh, I forgot to mention a fairly new radiator was installed about 6 months ago.
Old Jun 7, 2008 | 09:45 PM
DC4R27's Avatar
Default Re: (integrawow)
are you losing coolant? check to see if all the hoses are tightened down properly
Old Jun 7, 2008 | 10:05 PM
D@9 A.D.B.'s Avatar
Default Re: (DC4R27)
make sure you radiator cap is good and holding the pressure in...the grommet maybe worn out...this happened on my da and the cap was the culprit...just try it its cheap
Old Jun 7, 2008 | 10:10 PM
Stevo-DA's Avatar
Default Re: (D@9 A.D.B.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@9 A.D.B. &raquo;</TD></TR><TR><TD CLASS="quote">make sure you radiator cap is good and holding the pressure in...the grommet maybe worn out...this happened on my da and the cap was the culprit...just try it its cheap </TD></TR></TABLE>
same prob on my DA, but also could be the new thremostat could be Sticky or not the right Temp rating
Jonathen Lee
Oct 8, 2018 02:18 AM
motegicivic
Jul 14, 2012 04:39 PM
zbra09
Dec 19, 2009 08:30 AM
BodyKits NW
Aug 7, 2007 09:57 AM
dacosta
10
Jun 22, 2005 11:43 PM
