axle seal leak after trans rebuild
Old Jun 7, 2008 | 05:44 PM
94b16teg's Avatar
Default axle seal leak after trans rebuild
I just finished installing my transmission after me and a friend rebuilt it. We got a whole kit with syncros and bearings and seals. Everything went ok untill i filled it and after I got about 1.5 qts in it it started leaking from the driverside axle. It doesnt look like its sealed that great. Is there different size seals? Did we do something wrong? I took it around the block a few times and it shifts perfect. Any help would be great.
Old Jun 7, 2008 | 08:19 PM
welfarepc's Avatar
its not so bad. you can easily change that seal with the tranny installed. just get the right seal installed and ur all good
OldMrAccord
Nov 24, 2010 02:27 PM
itsLOUiSduh
Oct 17, 2008 12:31 PM
inh
May 21, 2008 04:30 PM
civicjoe8
Apr 11, 2006 08:52 PM
