tang or heim for aftermarket radius rod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rorik »</TD></TR><TR><TD CLASS="quote">And if you hate heims, like me, the johnnie joint might be a legit alternative..</TD></TR></TABLE>
You hate heim joints? Its a component--I could see hating it for certain applications, but hating the actual unit itself?
Problem is that Johnny Joints, in their smallest size, is 3/4"-16 thread. That's big.
A Johnny Joint (QA1 is releasing their Rock End next month which are similar, may come in a smaller size) is basically a hiem joint combined with a poly bush. It has a higher misalignment than a heim (around 40 degrees or more), and can handle higher shocks / jaring. It also will absorb road noise.
I'm not sure what you mean by 'tang'. If it is just basically a clevis/rod/eye/bracket, its not going to work because the radius rod needs to move on more than one axis.
If this is for a street car, you probably could use a self lubricating chromoly heim (2 piece would save some money), probably 5/8" shaft. It would be around $15 each.
You could just use a spherical bearing instead of the rubber bushings and use the original rod end.
yeah ive looked into the sphearical bushing, pretty expensive...
im gonna look around and try to find a supplier around vancouver who can supply a wide variety of hiem joints. seems like the best solution
Johnny Joints are about $40 and they should be stronger (maybe not in static, but certainly in shock). I'm using it on a project, ordered some so we'll see how they work.
Summit Racing has a pretty good selection of QA1 units.
RyanStevenPhillips
Oct 7, 2008 07:11 AM
577HondaPrelude
51
Jun 4, 2005 01:01 PM
DOMKID
Mar 17, 2004 12:31 AM
