best drag racing susp setup
Old Jul 16, 2002 | 08:07 PM
highbrid's Avatar
Default best drag racing susp setup
Ive done a search and cant get any straight answers on this. What would everyone use or what do you use as far as springs/coilovers, shocks, and anything else that goes along with it. (On a budget) Bushings are a given, but are there any other small things that you would do for a pure race car that sees no street duty. Has anyone tried to use just a straight metal rod or tube for back shocks? I am just trying to decide on my ideal setup.
Old Jul 16, 2002 | 10:02 PM
J.R.'s Avatar
Default Re: best drag racing susp setup (highbrid)
I would like to know also !!
Old Jul 16, 2002 | 11:36 PM
ProstockH22crx's Avatar
I had a daily driven allmotor crx with consistent 1.70 60ft times. I had kyb(silver) front and back with skunk2 coilovers. 450lbs in the front and 900lbs in the rear.
I have a friend that was getting 1.60s full race allmotor same suspension except he put ratcheting type tie downs(small ones) from the top chassis to the fork in the front. If you will be using wheelie bars, my cousin's race car gets 1.5 60ft times (quick 8 car) with front kyb agx on 900lb skunk2 coilovers with some jegs.com 80lb springs in rear. But then again it also depends on the cars power, slicks sizing, and clutch. Hope this helps.
Old Jul 18, 2002 | 11:18 AM
bigblockEG's Avatar
Default Re: best drag racing susp setup (ProstockH22crx)
a good set up for the street/styrip is koni yellows, tokico 5-ways, with skunk springs. I like the drag springs for the rear. I think they are a bit more than 900 lb's too, not sure howmuch though
Old Jul 18, 2002 | 04:01 PM
highbrid's Avatar
Default Re: best drag racing susp setup (bigblockEG)
What do most of the pros in the all motor class run? Maybe I havent looked all that hard or noticed it but do many of them use wheelie bars?
Old Jul 18, 2002 | 04:19 PM
ExospeedAMcrx's Avatar
when my car was daily driven. all I was using were stock shocks with intrax springs.
the rears were switched out with solid suspension at the track.
SOHC ALL MOTOR 1.7 60 fts on 14" and 13" slicks.
Wil
Old Jul 18, 2002 | 06:54 PM
earl's Avatar
DO NOT DO THIS. Way to dangerous. You got to stop the car also.
Old Jul 18, 2002 | 07:06 PM
ninesecrx's Avatar
Default Re: best drag racing susp setup (earl)
Its also illegal.
Old Jul 18, 2002 | 10:22 PM
Default Re: best drag racing susp setup (ninesecrx)
yeah its not the "best" way to get good 60s. it was so budget back then.
And it is illegal in the classes.
but we all went through it all sometime.. i remember when alot of the PRO racers were strapping the suspension down or welding the shocks back in the day.
Old Jul 19, 2002 | 12:13 AM
SIK IN DA HED's Avatar
New User
Default Re: best drag racing susp setup (exospeedAMcrx)
ill tell you one thing... shocks to make a difference. so do those z10 traction bars.
Old Jul 19, 2002 | 08:56 AM
Mikey3000's Avatar
Lamb struts . wanna spend 10 g's?
Old Jul 19, 2002 | 09:55 PM
88crxoncrack's Avatar
Default Re: best drag racing susp setup (Salvatore Leone)
try some Strange springs. they're nice on a budget. anybody remember the Snot Rocket???
jv88_dc2
Jun 21, 2010 01:21 PM
extremeracer
Jun 2, 2010 12:50 AM
all-mtr-teg
Suspension & Brakes
Jun 30, 2009 05:13 PM
nfakbc
Northwest (Sales)
Aug 29, 2008 09:35 AM
miller
Feb 4, 2003 02:32 PM
