extended lug studs
Old Jun 7, 2008 | 04:22 PM
crv-techu's Avatar
Default extended lug studs
do you have to remove the bearing to install skunk 2 extended studs on the front of a 95 integra? i herd that you can pull out the hub with a slide hammer a bit and install them ? has anyone on here installed them before?
Old Jun 7, 2008 | 07:04 PM
gen2fanatic's Avatar
Default Re: extended lug studs (crv-techu)
Although it mayyy be possible, I'd recommend pulling the hubs off...
...so you can install the extended studs in NEW bearings and get it all out of the way
Old Jun 7, 2008 | 07:31 PM
crv-techu's Avatar
Default Re: extended lug studs (gen2fanatic)
i need this info because me slicks wont fit on the stock studs very well
Old Jun 7, 2008 | 09:02 PM
bigislandc2's Avatar
yes the hubs need to come off. you should also change wheel brg. while there out. somtime when installing they break.....
Old Jun 7, 2008 | 10:15 PM
Stevo-DA's Avatar
Hubs have to come off i just got done doin them on my DA, check out my Build thread if you want an idea
Old Jun 7, 2008 | 11:28 PM
inspiration's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crv-techu &raquo;</TD></TR><TR><TD CLASS="quote">do you have to remove the bearing to install skunk 2 extended studs on the front of a 95 integra? i herd that you can pull out the hub with a slide hammer a bit and install them ? has anyone on here installed them before? </TD></TR></TABLE>
There is the other way. Where you have to notch off the shielding by doing this you have to take each stud one by one. I have an article here somewhere it was done long time ago.
Old Jun 10, 2008 | 01:51 AM
4drteggy's Avatar
Default Re: extended lug studs (inspiration)
its better to replace the bearing since your doing the studs now anyways
bmwe362006
Feb 23, 2009 06:21 PM
Quickridez_3
Sep 30, 2008 04:08 PM
ALLMOTOR CRX
Mar 14, 2007 10:08 PM
skankz_em1
Jan 31, 2004 08:01 AM
spettinger
May 4, 2003 10:03 PM
