Repairing GSR Crankshaft
Old Jun 7, 2008 | 02:20 PM
MeathooK's Avatar
Default Repairing GSR Crankshaft
Have been having a pretty annoying vibration/noise for quite some time after getting my crank pulley replaced by a mechanic, and today decided to take it apart w/ a friend helping me out, and found out what the problem was:
and the terrible jimmy-rigged key they made
... I know I can buy a new key for like 3$...
...but is there any machine shop that can fix the key hole on the end of the crank? Or am I looking at getting a new/used crank?
Thanks.
Old Jun 7, 2008 | 02:29 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
ouch man, holy crap dude. And that is why I don't like letting other people work on my car.
Not sure if that's repair-able or not.
Old Jun 7, 2008 | 03:11 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: Repairing GSR Crankshaft (MeathooK)
IMO, that cannot be fixed. There is nothing to machine since the metal is missing. You could weld and then machine, but you would lose the tempering of the metal. Just buy a new crankshaft.
Old Jun 7, 2008 | 03:29 PM
Community Builder
And send that shop the bill for the crankshaft while you're at it.
Old Jun 7, 2008 | 03:34 PM
MeathooK's Avatar
Oh, they'll be hearing from me early next week. Don't you worry about that.
Old Jun 7, 2008 | 05:47 PM
all-mtr-teg's Avatar
Since you and your friend took it apart, there is no way you can prove that the shop installed that key. It'll be your word against theirs in court. Good luck.
Old Jun 7, 2008 | 07:57 PM
MeathooK's Avatar
Ah, I wasn't going to take them to court, haha...would cost more in lawyers fees than it's worth. Just going to make sure he knows I'm not happy..hopefully he'll cut me a deal, I've brought numerous cars to him, and always pay him what it's worth. He means well, hopefully he'll understand.
Old Jun 7, 2008 | 10:43 PM
I don't really think they installed the wrong key or modified it, I think they didn't torque the bolt down tight enough and when you started up the motor the loose pulley caused the key to damage the crank, either way, good luck resolving the matter.
Old Jun 8, 2008 | 12:05 PM
Community Builder
Default Re: Repairing GSR Crankshaft (all-mtr-teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all-mtr-teg &raquo;</TD></TR><TR><TD CLASS="quote">I don't really think they installed the wrong key or modified it, I think they didn't torque the bolt down tight enough and when you started up the motor the loose pulley caused the key to damage the crank, either way, good luck resolving the matter.</TD></TR></TABLE>
Most likely they lost the key when they pulled the crank pulley off, and then just stuck in something they had laying around.
Just because the bolt is loose should not make that happen.
Old Jun 8, 2008 | 02:08 PM
95 integra's Avatar
Default Re: Repairing GSR Crankshaft (PatrickGSR94)
BTW, that wouldn't cause a vibration or noise as long as the crank pulley is bolted down tight.
Old Jun 9, 2008 | 08:49 PM
MeathooK's Avatar
The pulley doesn't seat correctly because of their wonderful key :-P The engine is all out of balance
ekx4
Aug 12, 2013 01:39 AM
ekx4
Aug 10, 2013 05:50 PM
212 degrees
Jun 8, 2009 08:09 PM
JaxTalonTurbo
Apr 6, 2006 01:47 PM
BeerMan
Sep 27, 2004 11:51 AM
