gsr or h22
Old Jun 7, 2008 | 11:05 AM
lilo_goki's Avatar
Default gsr or h22
should i keep my gsr w/b16 tranny or do a h22 swap. if i do a h22 swap, should i go h2b or just h2h, heard from some people that h2b isn't worth it and the h tranny is good already. i did 13.5 with my gsr.
Old Jun 7, 2008 | 11:28 AM
98vtec's Avatar
moderator emeritus
Default Re: gsr or h22 (lilo_goki)
b series people will say keep the bseries
h series people will say go h series
h2b people will say go h2b
Old Jun 7, 2008 | 12:02 PM
lilo_goki's Avatar
yea i kinda knew that but the horsepower and torque from the h22 suprise me with just basic bolt ons. i'm happy with my gsr doing 13.5, but seems like i want more top end power from all motor.
Old Jun 7, 2008 | 12:12 PM
b19coupe's Avatar
Built K24 with a GT35R
Old Jun 7, 2008 | 12:51 PM
lilo_goki's Avatar
lolz, gt35r, that's not all motor power. don't wanna go turbo.
Old Jun 7, 2008 | 02:46 PM
88Hatchy's Avatar
Default Re: (lilo_goki)
Keep the GSR, after market parts are less expensive. H series trannys suck
Old Jun 7, 2008 | 03:49 PM
NAH2B's Avatar
Default Re: (88Hatchy)
well i have had built b series and built h series as well as both stock.
going h series is a no brainer unless someone can figure out how to get low 12's out of a stock gsr motor
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88Hatchy &raquo;</TD></TR><TR><TD CLASS="quote">Keep the GSR, after market parts are less expensive. H series trannys suck</TD></TR></TABLE>
it depends on what kind of condition its in and how you treat it.
but i will agree after having both that nothing feels or shifts better than a b series tranny
thats why we now have the best of both worlds.....H2B
Old Jun 7, 2008 | 08:05 PM
lilo_goki's Avatar
yea i saw ur numbers NAH2B, those are some nice numbers for ur stock h2b. how hard is it to do h2b, did u use the evo kit or qsd and how's the axle align.
Old Jun 7, 2008 | 10:44 PM
b.series's Avatar
H2B FTMFW!!!!!!!!!!!!!!!!!
i would say to go with the evo kit, because its slightly less work and they pretty much cost the same. and i havent heard any axle complaints on the evo kit.
Old Jun 8, 2008 | 09:50 PM
lilo_goki's Avatar
kewl, if i go h2b then i'll get the evo kit.
Old Jun 9, 2008 | 09:33 AM
h22crxpwr's Avatar
Default Re: (b.series)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b.series &raquo;</TD></TR><TR><TD CLASS="quote">H2B FTMFW!!!!!!!!!!!!!!!!!
i would say to go with the evo kit, because its slightly less work and they pretty much cost the same. and i havent heard any axle complaints on the evo kit.</TD></TR></TABLE>
?????? whats less work on it? and how do they cost the same?
Evo kit is $1200+
QSD is $750+
care to elaborate on what "Axle complaints" the QSD kit has??
Either kit will work. and H2B will put u at or over 200 whp..
we ran 12.2 in a daily driven full interior crx with a stock H2B and cheapy ebay header with 1.8 60'....
Old Jun 10, 2008 | 05:49 PM
lilo_goki's Avatar
Default Re: (h22crxpwr)
damn nice et, but the crx is so light compare to the civic eg's. what tranny are u using on ur h2b, would a gsr be alright or should i just get the b16.
Old Jun 10, 2008 | 08:56 PM
h22crxpwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilo_goki &raquo;</TD></TR><TR><TD CLASS="quote">damn nice et, but the crx is so light compare to the civic eg's. what tranny are u using on ur h2b, would a gsr be alright or should i just get the b16.</TD></TR></TABLE>
User 2fastgsr just went 11.99 with a basically stock H2B swap. just a skunk2 mani, throttle body and custom header, no cams, stock head, stock block.. in a coupe!
the crx is a DX not that light.. weighed in at right around 2000lbs.
we are using a cable b16 trans... i would get a b16 trans instead of the gsr if i were u..
Old Jun 11, 2008 | 05:44 AM
2fastGSR's Avatar
King of the One Liners
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">b series people will say keep the bseries
h2b people will say go h2b</TD></TR></TABLE>
Blake hit the nail on the head.
My opinion will fall right in line with this.
Sell your gsr motor, buy an h22. Buy the qsd kit, use your same b series mounts, clutch, fllywheel, etc.
Throw it all in and call it a day.
My motor made 208 with just boltons and a street tune. Can a b series do that ?
Not knocking the b series by any means because they can make sick power, but if your contemplating it, for just a little more money why not go H.
Plus with this recent H2B fad that has been exploding , i think more companies will eventually put some aftermarket parts out for the H
Old Jun 11, 2008 | 06:02 AM
mar778c's Avatar
Community Builder
Community Influencer
Default Re: (2fastGSR)
I have a b-series, a pretty good one. If I started today and had a 92 and above year civic, I would go H2B. H2B in a EF is a pain due to hood or header clearance.
Old Jun 11, 2008 | 09:41 AM
lilo_goki's Avatar
kewl, i have a 94 civic si, i might just sell my gsr motor, but the fact is that mine's ref'd already. do i still use the integra shift linkages for the h2b, and i only use the tranny side mount for the h2b right, not the driver side and rear mount.
Old Jun 11, 2008 | 09:48 AM
h22crxpwr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilo_goki &raquo;</TD></TR><TR><TD CLASS="quote">kewl, i have a 94 civic si, i might just sell my gsr motor, but the fact is that mine's ref'd already. do i still use the integra shift linkages for the h2b, and i only use the tranny side mount for the h2b right, not the driver side and rear mount.</TD></TR></TABLE>
you use the B series trans, linkage, rear mount, half shaft, axles, and all mounts, the QSD kit has an adapter for the drivers side mount.
the EVO kit uses its own custom mounts but the motor sits lower to the ground..
Old Jun 12, 2008 | 11:25 AM
lilo_goki's Avatar
so the evo kit would be better for hood clearance than the qsd kit, but the qsd kit requires only a b series tranny and u can still use all the other b-series stuff right.
Old Jun 12, 2008 | 05:03 PM
NAH2B's Avatar
i dont have any first hand experience w/ the qsd kit, but from the pics i have seen i would not want to go that route.
the evo kit went in w/o any problems and everything fits perfectly i was very impressed w/ the quality and fitment of this kit. the axle angle seems perfect and there is plenty of ground clearance on my car. i didnt even have to shave the crank pulley
basically you use everything from the b series except for the motor itself. the evo kit comes w/ its own mounts and flywheel. you will use the b series tranny, clutch, axles, intermediate shaft, and slave cylinder. all you need is an h series longblock
oh yeah, my hood even closes w/o spacers too
Old Jun 13, 2008 | 03:13 PM
Shadowz7429's Avatar
Alot different in my ek lol
Old Jun 14, 2008 | 06:41 PM
88ED8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">go h2b</TD></TR></TABLE>
Thats right, H2B is the way to go
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NAH2B &raquo;</TD></TR><TR><TD CLASS="quote">i dont have any first hand experience w/ the qsd kit, but from the pics i have seen i would not want to go that route.</TD></TR></TABLE>
QSD FTW!!!!!
Old Jun 15, 2008 | 06:08 AM
NAH2B's Avatar
Default Re: gsr or h22 (88ED8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 88ED8 &raquo;</TD></TR><TR><TD CLASS="quote">
QSD FTW!!!!!</TD></TR></TABLE>
why?
401tuner
Jan 16, 2008 05:02 PM
4LugR
37
Feb 27, 2007 08:32 PM
Nov 17, 2005 06:38 AM
thomst4R
10
May 9, 2005 07:17 AM
AllMotorDC2
Jun 7, 2003 11:08 AM
