clutch seems to slip....
Old Jun 7, 2008 | 10:04 AM
joedeo72's Avatar
Default clutch seems to slip....
when going from first to second, the clutch seems to stay engaged for a second or two after pedal is released.
i hope its just the clutch and not something worse, any thought?
thanks
Old Jun 7, 2008 | 10:36 AM
elektronsi's Avatar
Default Re: clutch seems to slip.... (joedeo72)
you may have a worn pilot bearing, warped clutch disk, master cylinder/slave cylinder leakage, bad pressure plate
check first for leaks, if neither master cylinder(located on firewall) or slave cylinder(located on tranny) are leaking, both the pilot bearing and pressure plate are commonly replaced and easily accesible when replacing a clutch
Old Jun 7, 2008 | 12:09 PM
joedeo72's Avatar
thanks for the quick reply
Old Jun 7, 2008 | 01:14 PM
sevendurt's Avatar
i had the same prob my car sat for 2 years before i bought it and the high temp grease dried out it might be that.
94_Teggy
May 11, 2009 10:58 AM
tigersball
Jul 9, 2008 09:45 PM
94accord718
Sep 19, 2007 07:42 PM
JFG Kevin
Apr 12, 2006 01:56 AM
92CIVICCX
Sep 26, 2002 05:16 AM
