starter/alternator differences w/ h22/h23
Old Jun 7, 2008 | 09:38 AM
h23vtec_dc2's Avatar
Default starter/alternator differences w/ h22/h23
so is the alternator and starter exchangable for h22 and h23 motors?
Old Jun 7, 2008 | 11:27 AM
Hawkze_2.3's Avatar
Default Re: starter/alternator differences w/ h22/h23 (h23vtec_dc2)
The alternator pulleys are different, H22 has 6 ribs while the H23 has 5. Starter should be exactly the same.
Old Jun 7, 2008 | 12:45 PM
Default Re: starter/alternator differences w/ h22/h23 (Hawkze_2.3)
so??
Old Jun 7, 2008 | 12:47 PM
there's like a total of four full ones, and two on the sides are like half.. guessing it's maybe 6 teeth
Old Jun 7, 2008 | 06:47 PM
SikB's Avatar
you need to count ribs on the belt or grooves on the pully. The two need to match. But if you run an H22 crank pully and alt but h23 a/c compressor you can run an H23 narrower belt with no problems.
Old Jun 8, 2008 | 05:38 AM
Acidcrakker's Avatar
Default Re: starter/alternator differences w/ h22/h23 (SikB)
Yes you can put the alts on either motor, you will just have to compinsate with a diffrent rib belt if you use a h23 alt on a h22 motor(5 rib).
H23 motor with h22 alt( 5 rib) as well
Old Jun 8, 2008 | 07:40 AM
G2IntegraGS's Avatar
Default Re: starter/alternator differences w/ h22/h23 (Acidcrakker)
yeah I had to swap the h23 crank pully onto the h22 so that my a/c compressor would work. then I jjust swapped the rrest of the pullies.
Old Jun 8, 2008 | 09:16 AM
Default Re: starter/alternator differences w/ h22/h23 (G2IntegraGS)
sounds like more work than its worth. You could of just kept the h23 belt on there.
Old Jun 8, 2008 | 10:31 PM
not doing a h23 vtec swap or anything... just wanting to know if they are innerchangable. cause im gonna be selling the alternator and i dont wanna say that it fits in a h23 when it doesnt.
Old Jun 9, 2008 | 04:26 AM
autoluder's Avatar
so what about the starter, does anyone know the differences in ludes, vtec, non vtec, auto or manual, ....
Old Jun 9, 2008 | 11:01 AM
Pullig's Avatar
Default Re: (autoluder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by autoluder &raquo;</TD></TR><TR><TD CLASS="quote">so what about the starter, does anyone know the differences in ludes, vtec, non vtec, auto or manual, ....</TD></TR></TABLE>
no difference btw the non vtec and vtec just btw the auto and manual ...
Old Jun 15, 2008 | 07:22 AM
autoluder's Avatar
so far what I have found out about starters is that the manual starters mount differently than that automatic starters.
Old Jun 15, 2008 | 05:07 PM
thanks guys.....
so CONCLUSION FOR STARTERS for h22 and h23
autos off the h23/h22 are a no go.
all manual h22/h23 works!!!!!!!!!
Old Sep 14, 2008 | 02:11 PM
newyorkboiiboii24's Avatar
Hey was up listen I got a h23 that im putting in a honda accord 4 door right so the parts from tha single cam don't fit like the timin belt because its a little of the pulley now I need a alternator,and power steering pump if have any of them part get @ mii on aim: newyorkpapi347 or call mii on ma cell 732 881 7800 ight thanks
blowngsr1
Feb 18, 2010 09:42 PM
pkolaboy
Jun 27, 2008 06:47 PM
AdReNaLiN
Feb 28, 2008 04:00 PM
h23vtak
Oct 5, 2007 10:48 AM
h23vtec_dc2
Jun 22, 2007 07:20 AM
