getting no spark, she wont turn over
i have an 93 eg hatch with a ls swap. i did not do the swap. i bought her swapped. it turned off on me when i was driving and then would not turn over. i checked the spark by pulling a wire and putting a plug in there with no success. theres no spark. im going nuts i cant figure it out. everything appears to be hooked up.
i cant find my diagnosis port, i tried to do that test where you find the plug near your ecu and close the connection in hopes to get the cel on my dash to go off. (i dont have that plug)
any advice would help. im about to take her to a shop and get ready to bend over.
i have new plugs, wires, rotor. not a cap though.
im unable to check my codes. the battery is fine. just no spark. it was runing perfect ever since i got her just all of a sudden she turned off. now no spark. just confused and wanted to know if anyone else had this problem. thankyou.
is it cranking over when you turn the key or do you get nothing when you turn it? and you SHOULD have a lil connector under your glove box by the right kick panel. matter of fact there should be two connectors, one for the check engine and one to hook up a scan tool to read your TPS, IACV etc. They might be tucked in good, mine were way up in there, took me a few minutes to find'em.
it might be your clutch switch. in order to start the car your clutch activates a switch which will allow the car to turn over and get spark and fuel. im not sure where it is located but that happened to my friend in his mini.
