flashing s light, transmision wont shift correctly
I,ve replaced the speed sensor and started up and test trip went fine. Next morning same problem was back. through this site found out how to get trouble
codes and came up with multiple codes. 1 2 3 5 7 8 14 (wow no wonder its flashing) Any help would be greatly appreciated, just bought car with the knowledge that the brakes needed done, little did I know that the rotors had to
come off the back of the hub which turned into quite the task. Any how, after all
that work this problem has now arose and I fret that I might have got took.
Thanks
Troy
Thanks
Troy
got the same prob my D4 light blinks and sometimes my vtec does not go off and my speedomiter dont work sometimes and i shifts funny im thinking of doing a auto to manual conversion i got everything i think but he clutch pedal and resavor clutch, fly wheal, linkedge, trans.
Thanks
Troy
Thanks
Troy
i'm gonna take a guess it was an auto with a standard conversion still running the original ecu?
I don't think the original poster is going to reply. He only has 2 posts over the last year.
This thread was posted on 06-07-2008.
na i said im planing to do a conversion its doing all that stuf, the D4 light blinks or flashes and when the speedomiter dont work the vtec dont kick in im thinking its my speed sensor
With the D4 light flashing you should be able to retrieve any diagnostic trouble codes that are stored on the ECU/TCU. Then you will be a step closer to knowing for sure if it is your speed sensor or not. Do a search for the SCS connector short, paperclip jumper trick or self diagnosis procedure if your not sure how to retrieve and read the codes.
