my car died on me help me out
Old Jun 6, 2008 | 11:35 PM
jdmh22na's Avatar
Default my car died on me help me out
ok heres the deal i have a jdm h22 swap o my 2000 that just finished this month. i drove it to vegas this past weekend to break in the new clutch and flywheel. it drove fine on the way down there. when i got there my tach started twitching pretty bad so i couldnt even tell what i was taching. then on the way back it felt like my car was running like ****. i would open it full throttle and it would lag(bog randomly) it got worse and worse as we went further then 20 minutes out from my destination i was trying to get up a hill and it wouldnt go at all. my car would jerk hard and then it just gave up and the engine cut out. i have no clue where to start i dont know if it could be a electrical or fuel problem. please help me out.
p.s. i was goin down the hill a couple times and i would push the clutch in to just drift down the hill and my engine would cut out. but then i let the clutch out and it would start again. i dont know if this could be related.
thanks
Old Jun 7, 2008 | 04:23 AM
bluedlude's Avatar
Default Re: my car died on me help me out (jdmh22na)
check your distributor. sounds like the ICM is going bad.
Old Jun 7, 2008 | 11:47 AM
captaindammit's Avatar
definately check the dizzy and the coil. if you have oil coming from beneath or around your dizzy, then its bad and you need a new one. or so im told
Old Jun 8, 2008 | 06:41 PM
gstrudler's Avatar
Default Re: my car died on me help me out (captaindammit)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by captaindammit &raquo;</TD></TR><TR><TD CLASS="quote">if you have oil coming from beneath or around your dizzy, then its bad and you need a new one. or so im told</TD></TR></TABLE>
If you're seeing a little bit of oil around the dizzy, it's most likely just the distributor o-ring that needs to be replaced. However, given the other symptoms, it does sound like either the ICM or coil needs to be replaced.
joiv21
Nov 5, 2012 08:57 AM
staz0loaf
Transmission & Drivetrain
Oct 16, 2012 07:46 AM
ShIntegra1993RS
Jul 4, 2011 06:27 AM
R015
Sep 2, 2008 08:40 PM
genetsang
Aug 22, 2004 10:51 AM
