SI hatch brake noise
I replaced my pads and rotors on all 4 because they were doing the high pitch squeaking upon braking. Now it is making the same high pitch squeak after a few days of the new brakes. What could be the problem?
Did you use the brake squeal glue behind the pads? The noise is caused by tiny vibrations between the pad and rotor. This is eliminated by using the brake squeal stuff.
On another brake note,
can someone tell me the exact size of the front and rear rotors for the 92-95 SI? When I ordered mine from advance auto the front rotors were too big but the rears were okay. Maybe the rear pads were slightly different than what it is supposed to be but it still worked...
Well also take in consideration on what TYPE of brake pads you bought. From what i know the METALLIC type of brakes always make a squeaking noise. Someone correct me if im wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dekorum »</TD></TR><TR><TD CLASS="quote">On another brake note,
can someone tell me the exact size of the front and rear rotors for the 92-95 SI? When I ordered mine from advance auto the front rotors were too big but the rears were okay. Maybe the rear pads were slightly different than what it is supposed to be but it still worked...</TD></TR></TABLE>
If you have a 94 Si with ABS, order front pads from a 94-01 Integra. If you have a 92-95 Si without ABS, order front pads for 92-95 Civic DX.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mortificationrock »</TD></TR><TR><TD CLASS="quote">Well also take in consideration on what TYPE of brake pads you bought. From what i know the METALLIC type of brakes always make a squeaking noise. Someone correct me if im wrong. </TD></TR></TABLE>
never had a problem with metalic pads squeaking all the time
have had a 93 SI since new never had to order pads for a dx to get the right ones just make sure that you get the pads for a non abs civic si
Modified by instructor74 at 7:18 AM 6/8/2008
ndogg810
Honda Civic (2001 - 2005)
Jan 9, 2007 07:10 PM
lv6l
Jan 24, 2006 01:36 AM
MugenHonda
Jan 27, 2005 09:03 AM
