dim headlights, no electrical power
tonight i get in my car to drive home and i start it. Doesnt want to start but finally cranks over. i flick on the headlights. They are super dim dashlights are also. When i do this i hear my fuel pump stop making the normal whine. Im not too sure what might be going on. All i did today was try to take off the front bumper. I pull the headlights out alittle but didnt disconect anything. I also took out my washer fluid bottle. Any info on others with a similar problem would be cool. thanks
check the wiring, sounds like 2 wires ( a ground and a positive) on something are touching on the horn bumper lights etc (anything under the front bumper)
Other then that check your grounds (rear tail light, thermo housing and tranny) and the fuse relays.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by andrewsmith85 »</TD></TR><TR><TD CLASS="quote">problem solved. Wires from the washer fluid pumps were touching causing a short. </TD></TR></TABLE>
i knew it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nerologic »</TD></TR><TR><TD CLASS="quote">check the wiring, sounds like 2 wires ( a ground and a positive) on something are touching on the horn bumper lights etc (anything under the front bumper)
i knew it
Eskimobob31490
May 22, 2011 06:18 PM
adip315
Apr 20, 2008 10:04 PM
aaronhume
15
Nov 30, 2004 09:41 AM
hybridbmw
Jun 18, 2004 06:50 PM
