Iac?
Old Jul 16, 2002 | 07:09 PM
91CRXSI's Avatar
Default Iac?
i need help my crx is running rough at idle. it jumps from 2000 to 900 rpms. So i replaced the iac and it does the same thing. Now if i unplug the iac it idles perfect but the check engine light comes on and it starts to run bad when i put it in gear. anyone know what this is?
Old Jul 16, 2002 | 07:15 PM
4gvtec's Avatar
Default Re: Iac? (91CRXSI)
did you get a code for the iac befor you changed it?
Old Jul 16, 2002 | 07:19 PM
91CRXSI's Avatar
Default Re: Iac? (4gvtec)
no i was just told to change the iac so i did
Old Jul 16, 2002 | 07:21 PM
4gvtec's Avatar
keep the iac pluged in and reset the ecu.then start it up and check the ecu for what code it is throwing.
Old Jul 16, 2002 | 07:25 PM
91CRXSI's Avatar
i already tried that and it throws no code
Old Jul 16, 2002 | 07:28 PM
4gvtec's Avatar
have you drove it when its doing this?
Old Jul 16, 2002 | 07:34 PM
91CRXSI's Avatar
yes with iac plug in it only jumps at idle. it runs ok when its at higher rpms
Old Jul 16, 2002 | 07:40 PM
4gvtec's Avatar
if you drive it ,it might throw a code then.some times it wont throw one till it is driven. give me a min on this.
Old Jul 16, 2002 | 07:42 PM
4gvtec's Avatar
did it just start doing this? did you mess with the set screw on the throttle plate,or if you tighten it to make it idle higher it will go from 900 to1500 and reat it .
cartune network
Apr 1, 2016 01:02 AM
SlipGear
Jun 26, 2008 05:37 PM
god.loves.ugly
Jul 27, 2005 07:32 PM
russian_racer
Jun 28, 2003 02:01 PM
